Old 10-05-2004, 07:26 AM
gsodonis's Avatar
gsodonis gsodonis is offline
Remote door locking/unlocking beep question
I am currently using the factory key fob remote to lock/unlock my doors with the security system off. The system verifies function with three rapid beeps of the horn. Is there a way to silence the beeps without disconnecting proper horn function? I plan on upgrading the horns and this will become very loud when I do.
My 2002 WRX had that ability (silent door lock/unlock & security activation) and I was hoping the SVX did as well. I have read the owners manual cover to cover and can't find anything on that.
Your collective help is appreciated.
Old 10-05-2004, 07:31 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Disconnect the horn.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 10-05-2004, 07:35 AM
gsodonis's Avatar
Re: Remote door locking/unlocking beep question
As I asked above: "WITHOUT disconnecting the horn."
Thanks for your feedback anyway.
Old 10-05-2004, 08:20 AM
Use air horns.
There would not be enough air supplied by the electric compressor during those 3 rapid beeps to activate the horns efficiently. During normal driving conditions though they would work very well.
Many members here have the air horn setup.
Old 10-05-2004, 08:36 AM
gsodonis's Avatar
Air horns
I was hoping that someone would suggest air horns; I was going to install some until the beeping issue popped.
Is there a consensus as to a good airhorn product?
Some recommendations from you air horn converts would be appreciated.
Old 10-05-2004, 03:11 PM
Any idea if there's possibly just a wire coming from the security module that controls the horns. Snip the wire then no more horns. Also shouldn't disrupt normal horn functionality.
Old 10-05-2004, 04:16 PM
There is a GREEN/BLACK STRIPE wire coming out of pin 16 in the security module that goes to the horns. If you have the Service manuals it is in the wiring diagram section 6-3, pages 51 and 71.
If you cut or disconnect the wire at the security module, it shouldn't blow the horns when the doors are locked or unlocked. The same color wire is also used to provide the ground through the horn switch for normal horn operation.
Here are the images of the diagrams
Old 10-05-2004, 04:17 PM
and here. Hope these help.
Old 10-05-2004, 06:53 PM
gsodonis's Avatar
Perfect, just what I was looking for
As always, thank you all for your help and input.
I still plan on installing a Piamm Riviera dual air horn, but will try the security disconnect as well.
Old 10-06-2004, 11:23 AM
Unfortunately cutting that wire will also give you a silent alarm.
