Old 10-04-2004, 08:54 PM
Removing condensation from the waterfall grille
Here is a thread for all you scientists and engineers.
There have been many threads on condensation and moisture buildup inside the waterfall grille. In the back of the grille is a small air "port" covered by a curved rubber hose, to keep water out while allowing air to move in and out, depending on the temperature. I noticed that when I washed my car today, my clear grille satrted to fog. I am assuming that the air inside of the grille was heated by the radiator and when I stopped the car and started to wash it the cold water on the grille caused the warm air inside the grille to condense.
Here is my theory:
Insulated window glass/sliding glass doors in the home remains clear all year long, despite the vast differences between inside and outside temperature, because the air has been extracted from between the two layers of glass, leaving a vacuum. No air-no condensation. When that vacuum is broken, air enters and condensation starts to form.
So I thought that I would...
Remove the grille and place it in a warm oven for awhile to dry out the condensation. Turn off the oven, removethe grille or leave it in the oven and allow it to cool to room temperature. I then connect a small piece of hose to the port in the back of the grille and the other end to the port on one of those "foodsaver" vacuum packaging systems. I remove all of the air from the grille and crimp and seal the hose at the grille before removing the vacuum line. Another product that is far cheaper is the Pump-n-Seal hand vacuum system
http://www.pump-n-seal.com/
Using the Pump -n Seal system, you could permanently seal off the "port" in the grille, drill another hole and use the "tab-chek" over the hole to remove the air. http://www.pump-n-seal.com/pumnseal2.htm
It seems now that there is no air left in the grille, there would be nothing to condense. Of course you would have to make sure that all seams of the grille were sealed with RTV prior to doing this. If it doesn't work, you are no worse off than you were before.
Is this sound logic and something that may work? A new grille is 266.00 from subaruparts.com and is guaranteed for a year. The Pump-n-Seal is only $11.95 plus shipping.
Old 10-04-2004, 10:31 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
I am no engineer, but I think that sounds like it just might work. I don't know if you could get it completely air tight or if you could get all the air out. I think air would slowly seep back in somehow over a long period of time. I think it's a very interesting experiment though and definitely worth a try.
Good Luck!
--Mike
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 10-04-2004, 11:34 PM
Reversing the process, you could add a hose to the port at the back of the grille and pump air INTO the grille while the grille was submerged underwater. Air bubbles would show you where the air was leaking out of the grille (much the same way that you submerge a tire in water you want to patch to find the hole)
If you could seal all of the leaks first, then vacuum out the air, the condensation should never return. Running a bead of clear RTV around the perimeter of the grille where the black plastic and the clear waterfall meet should do the trick.
Old 10-04-2004, 11:44 PM
Yoda3000's Avatar
sounds good. just make sure you seal of that hose good and tight after you suck the air out.
Old 10-05-2004, 02:30 PM
I wouldn't vacuum the air out...just bake it and seal it. It's still going to pull air back in eventually.
Old 10-05-2004, 05:54 PM
svx_commuter's Avatar
That's is a great plan. I really like it and I think it would work as you say as long as the waterfall assembly is sealed up.
I have noticed that my waterfall grill will get condesation right after I clean it. You know with Novis plastic cleaner. Than after about a month it goes away. Any idea why? It has been suggested that there is a hole in the plastic from a rock and when I clean it the hole opens up. Pulling a vaccum on the part is a good idea. What about clear coat? Can that be sprayed on the plastic?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-05-2004, 06:28 PM
Leaky lens.
There must be a leak between the clear lens and the backing plastic piece. As you say it gets water in when you wash it. This is when there is water laying along the seam, between the two pieces, and when it is cooled, it pulls the water in as the rubber drain has a one way opening, to let air out, but closes to prevent air from entering.
Your idea of blowing air in, while it is under water to find the leak worked for me, to find the leak in my rear tail light lens, that I sealed with silastic. Hasn't leaked since.
Old 10-05-2004, 07:41 PM
Re: Leaky lens.
Originally posted by oab_au
...it pulls the water in as the rubber drain has a one way opening, to let air out, but closes to prevent air from entering.
The rubber drain (curved piece of rubber hose) on the back of the grille is to keep water from entering the grille through the "port"
When I pulled the hose off of the end of the port, there was just a small hole there, not a one-way valve or opening, just a hole. I guess the purpose of the hose is to allow air to escape from the hole but also allow air back in, but not water.
Or do you mean the curved hose itself has a one-way opening? I just assumed it was a normal piece of hose and you could blow through either end without obstruction.
Old 10-05-2004, 07:54 PM
Re: Re: Leaky lens.
Just went out to check, you are right, I thought that the end of the hose was flattened to act as a valve, gawd wrong again, but I recond the rest is right. My tail light sucked water every time I hit it with the hose when hot.
Old 10-05-2004, 09:03 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Re: Removing condensation from the waterfall grille
Is this sound logic and something that may work? A new grille is 266.00 from subaruparts.com and is guaranteed for a year. The Pump-n-Seal is only $11.95 plus shipping. [/B]
There is also a 3rd option...make me an offer on the waterfall I've got up for sale. Never had any condensation issues with it
Old 10-06-2004, 09:17 PM
Mr. Bill's Avatar
Mr. Bill Mr. Bill is offline
Where the heck is Millington?
I also believe they fill this vacuum with a gas - don't know if that is for condensation or not.
1997 LSi, Brilliant Red, 62K, #204
1999 Outback Limited, Black, 182K
US Navy Retired (CWO3)
