Old 09-22-2004, 07:57 PM
SVX_MY_BABY's Avatar
are Poly bushings noisy?
I was told that there is a trade off with poly. Better performance but at the cost of more transmitted road noise. My rubber bushings on my sway bars are shot. Comments please.
Old 09-22-2004, 08:26 PM
wawazat??'s Avatar
Yeah, I'm still around
Noisier because of their increased durometer (hardness) and they squeak and require periodic lubrication.
Todd
Down to none
Old 09-22-2004, 08:45 PM
mbtoloczko's Avatar
sans SVX
They do squeak a bit in colder weather, but usually only on larger bumps. I haven't notices an increase in road noise, but I have noticed that square-edged road bumps are a felt a little more in the front suspension.
Mychailo
Visit my locker
Old 09-23-2004, 06:23 AM
dcarrb dcarrb is offline
I'm having a hard time imagining why firmer sway bar bushings would transmit more road noise. If anything, it seems the reverse would be true. And stock bushings can be noisy. Recently, my rear bushings (which appear to be in perfect shape) started binding the sway bar, which would build-up tension that released with a pronounced thunk when the car's weight shifted. I shut 'em up with bearing grease (and have since learned that the prevailing wisdom holds that to be a bad idea).
dcb
Old 09-23-2004, 06:27 AM
BoondockSVX
I haven't noticed any additional noise with poly swaybar bushings in my other cars.
- Jim
Old 09-25-2004, 03:22 PM
immortal_suby's Avatar
Thread Killah
- Jim
me either.
Locker Link
2015 BRZ Limited 6MT
Old 09-25-2004, 04:12 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
Energy suspension and others usually warn that poly bushings will be noisy (squeeky) in cold climates. Not a problem if you live down south....or at the gates of hell in south-central Texas.
I do know what is noisy.....stock bushings that have broken into three pieces. Finally got around to changing them with new stock bushings.....much better. Still plan on the poly upgrade.
If you're gonna grease rubber/poly suspension bushings make sure you use a silicone grease. Regular petroleum based grease will eventually degrade the bushings.
Also, why is it that subaru designed the engine to develop a leak so it drips motor oil all over the swaybar bushings? Maybe designing in some work for the dealers?
