Old 09-14-2004, 12:34 PM
Crash
clunk on take off
so a month ago my car started a noticeable clunk when taking off. It feels like the tranny is not catching as soon as you give it gas. It shifts fine for the most part. Also every once in a while it almost has a chugging motion in third, but no change in rpms. To top it off, I went to rotate my tires just now and when jacked up in park the front tires keep turning.
Any ideas!
Old 09-14-2004, 01:39 PM
Peach
clunk
The clunk you hear or feel could be the carrier bearing and or mount in the 2 piece drive shaft "propellar shaft," unit. Also if you can raise and support vehicle, check tranny crossmember the rubber mounts on it, the engine mounts and rear differential mounts. As for your wheel free spin in P, all I can say is when my SVX is up off the ground it does it too.
Old 09-14-2004, 01:41 PM
Re: clunk
mine too, scared the piss out of me the first time I noticed
Old 09-14-2004, 02:05 PM
Peach
Re: Re: clunk
Me too!
Old 09-14-2004, 02:13 PM
dcarrb dcarrb is offline
Do your cars hold on an incline with the selector in PARK?
dcb
Old 09-14-2004, 02:25 PM
dcb
Yeah, that is the part I don't get.
I don't think I have had it in the air with the engine running since I got the Reman installed this past winter. So, I'm not sure if it was a symptom of a bad trans, or if it just another "Freaky" SVX thing...
Old 09-14-2004, 02:39 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
When you got it off the ground do the tires rotate in the same direction when turned by hand? If not, and they shouldn't, that explains how it holds on a hill.
Old 09-14-2004, 03:07 PM
Mr. Pockets's Avatar
Moderator
Right. Because the wheels are on a differential, you'll be able to rotate one at a time, but both of them won't turn in the same direction.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 09-16-2004, 03:02 PM
Crash
Sometimes it holds on an incline other times it rolls back. Just like the clunk, it is a sometimes thing. I take off at one light nothing, I take off at the next and it clunks. I have always eased into motion with the car never ever do I launch it. Oh also it takes longer to catch when I shift into drive or reverse. I heard someting about that once. Its like its thinking or something.
