Old 09-02-2004, 07:49 PM
MikeInd
Bad Gas Mileage
94 Lsi, Can the belt skip on one side? When I left Indianpolis the car was running great....got to Seattle....idle is very rough.... and BAD gas mileage.
I got one check engine light...only one time....
Help....
Also, anyone in the NW-Seattle area have a good garage to recomend?
Thanks
Old 09-02-2004, 08:29 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Question
What octane level did you use to run back in Indy and what octane level are you running now?
-Chike
P.S. I've heard of SVXs running really rough when low grade octane is used. The bad gas mileage would be an indicator of the knock sensors causing the ECU to dial back timing to prevent detonation.
2006 Steel Gray WRX TR (sold)
Old 09-02-2004, 08:35 PM
MikeInd
Indy-93
Seattle-92
I get hesitation when I start to accerate.....then it launch like a rabbit
Also, I feel a VIBRATION when I rev it up
Any ideas?
Old 09-02-2004, 08:44 PM
Chiketkd's Avatar
Could be many things - dirty fuel injectors, bad spark plugs, an O2 sensor going bad...
However, since you switched from Midwest 93 octane, to West coast 92, I'm almost wondering if there might be bad gas at the place you purchase it from.
Do this, go to your local autoparts store and get a $2 bottle of octane boost and add that at your next fill-up. See if your problem steadily goes away over the period of that tank or persists.
If the problem persists, then it's not related to the gas. If it goes away, then I'd suggest changing gas stations and/or buying Longassname's Stage 1 chip and running the 87 octane code.
-Chike
Old 09-02-2004, 09:30 PM
n00b on demand's Avatar
-Chike
clean your throttle body and check get those O2 sensors replaced or run the codes...get those fuel injectors cleaned... or fuel filter changed....im having the same problem with hesitation and the launch lol
Old 09-02-2004, 11:01 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Originally posted by MikeInd
Indy-93
Seattle-92
Any ideas?
vibration ? make sure your crank pulley isnt coming apart...
check rest of the obvious stuff mentioned
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 09-03-2004, 09:06 AM
If you got a check engine light then check the code. It should give you a hint to what's wrong.
Old 09-03-2004, 09:20 AM
Chiketkd's Avatar
Agreed. Most parts stores have code readers taht they can hook your car up to. Otherwise, use the Subaru diagnostic process to pull the codes.
-Chike
Old 09-04-2004, 03:17 PM
angrydan angrydan is offline
If the idle is really rough, you could have dirt and junk in your fuel lines, or a clogged injector. This recently happened to my brothers Firebird. It was idling all over the place and would go from nearly stalling to revving over 2000rpms. I took it to my mechanic and he flushed out the injectors, fuel lines, and changed the fuel filter. All in all, a cheap fix. It's worth a shot...
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 09-05-2004, 04:18 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Re: Bad Gas Mileage
The answer is YES!!!
It happened to me last year. I was all set to go to Reading V on Saturday morning, when to pick my son up when it happened.
The t-belt slipped due to a poor installation, ME. It only jumped on the left side. The whole left side of the motor shut down. The ECU when into "safe mode" and only ran on the right three cyclinders. Once I realigned the t-belt it was fine. The computer kicked a left O2 sensor code when this happened. The car was not very driveable either.
If you jumped a tooth on your t-belt you would know it. Needless to say I never made Reading V, and I lived at the MD/PA line. Now I have to drive from Minneapolis to go to Reading VI.
I do not think you skipped the belt.
You would have to rev up to 3500rpm to have a smoother idle. there would also be no power what so ever.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
