Old 08-31-2004, 05:32 PM
tancred
SVX use dry sump?
Does the oil system in a SVX use a dry sump system?
Old 08-31-2004, 05:50 PM
87f383's Avatar
87f383 87f383 is offline
no.
Old 08-31-2004, 08:22 PM
Mr. Pockets's Avatar
Moderator
I don't know of any production car that does.
The new BMW V10 that'll be in the new M5 supposedly has a dry sump, but really it's just an extra pump thrown in there, I think.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-31-2004, 08:30 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
No, no....
In fact, I've been told, the stock pan is baffled well enough to not even have to think about adding a hydraulic accumulator to prevent oil starvation in high g turns.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-03-2004, 09:55 AM
tancred
Porsche's have dry sump systems from the factory. I was reading something about boxer engines using them, so I wasnt sure if the SVX followed...
Old 09-03-2004, 09:57 AM
tancred
This seemingly illogical procedure is necessary because the 911 engine has a “dry sump” lubrication system just like those used on many racing and most aircraft engines. When the engine is at normal operating temperature the oil reserve is all pumped out of the crankcase, through the filter, and into the oil tank. This situation prevents the oil from surging and splashing around in the crankcase, thereby reducing windage losses. Thus the engine can produce more power output and the oil has less heat to disperse.
Old 09-03-2004, 10:07 AM
Moderator
It's a common misconception that since the SVX has a flat 6 and most Porsche models have flat 6s that they share a common heritage. They don't. Not in the least.
Anyway, I didn't know that Posche engines had dry sumps. I just looked around a little and it seems that the practice is a holdover from their air-cooled days.
2005 Outback
END OF LINE
Old 09-04-2004, 08:28 PM
The Deviant
However...
I have read about some aircraft-modded SVX engines with dry-sump systems installed... I d something once and got some amateur aircraft site talking about it...
I don't know the cost/availability/form/functionality/etc. of these systems, or how they'd fit on the engine in a car, but if you decide to stick your engine in a plane, you should be set
