Old 09-04-2004, 11:26 AM
simonton
that's amazing! it looks like it came stock like that. Where'd you get that?
Old 09-04-2004, 02:20 PM
It's a stock shifter and shifter boot out of a 95 Impreza....
Old 09-05-2004, 09:29 AM
mbtoloczko's Avatar
sans SVX
Originally posted by Chiketkd
If you do the work yourself, you probably could come out in the 1-3K range - and be on the lower end of that scale if you pick up a 5spd parts car like a wrecked Legacy/Impreza.
If you need a shop to do it for you, a range of 3-5K may be more realistic. However, if you know of a good mechanic who'll do the work in his/her free time, then you'll save a bundle on labor.
-Chike
I agree with Chike on the price. Used parts are cheap. New parts are very expensive. I recommend installing a new flywheel, clutch disk, pressure plate, and throw-out bearing.
Mychailo
Visit my locker
Old 09-05-2004, 03:17 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
if you want an auto id go with a built one from motorsports 2700$
and dayle is preaty adimint about it being very durable.
from what i hear with dayles driveing style it better be strong.
http://store.yahoo.com/svx-motorspor...rformance.html
Old 09-05-2004, 05:17 PM
simonton
hows this? Sounds good to me...
