Fastchip
Anyone know where i could find a fastchip for the SVX i'd really like to get it up there in hp round 265 or more.
anyone else know about this tornado air filter does it really work?
look in the mod section there is a upgraded ECU that just came out for the SVX. I dought the tornado does any thing at all. I would rather invest that money into a STi air filter, you would gain more horse power and then you have a STi part on your car
Forget the tornado -
get longassname's ecutune chip, thoroughly clean the intake (remove it and clean the runners as well) , put in a new air filter, make sure your plugs are in good shape. beyond that you are going to need a 50 shot of nitrous to hit 265hp unless you want to spend big $ on a turbo or supercharger setup.
I think you could get 265 horse, with the stage 1 ecu, Sti air filter, a upgraded exhust, ignition upgrade MSD, light weight crank pullie, and the new intake spacer so heat dosent transfer to the inake manifold as much. All these mods should also improve gass milage. This is not the short term cheapest way to get the power, as you can just go get some nitrus, a 75 shot but then you will need to refill it, and you wont get better gas milage.
True, but other cars have seen gains of 5-10hp from using them - our cars should be no different. However, I expect the improvment for our cars to be on the lower side of that scale...
-Chike Quote:
I Got 1)Accel air filter 2)Stebro exhust 3)Light weight pulley 4)MSD Ignition 5)ECUtune stage 1 6)Grounding upgrade
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
I don't think 250 is a far cry with all those toys. IMO the stock figure of 230 is a bit of a lowball. all the stuff you have tacks on a horsie here and there. high 240s at least.
IggDawg is cool -IggDawg 1992 Teal SVX LS-L 160k miles 4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE 1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k |
