Old 06-16-2004, 06:54 AM
Question Sring rate on front struts?
Would someone with the FSM's look up the stock spring rates in pounds per inch for the front struts for me.
TIA
Old 06-16-2004, 07:56 AM
mbtoloczko's Avatar
sans SVX
140 lbs/in. The rears are 110 lbs/in.
Mychailo
Visit my locker
Old 06-16-2004, 08:15 AM
WOW, is that all....the XT6 has 175 lbs/in.....would've thought the SVX would have heavier ones, since it weighs more....
Thanks
Old 06-16-2004, 09:37 AM
mbtoloczko's Avatar
sans SVX
Thanks
Yep, as Porter said, the stock spring rate is criminally soft.
Mychailo
Visit my locker
Old 06-16-2004, 09:39 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
But it gives it such a luxurious ride.
I guess its all about making sacrifices.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 06-16-2004, 09:48 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
That stock spring rate is kinda weak...
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-16-2004, 09:58 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
and just look, the 30 lbs/in difference gives you a built-in understeer condition. Mychailo - what's the relationship between sway bar rate and coil spring rate (i.e. how much will increasing the sway bar rate contributes to the overall spring rate at the wheel) -- is it just a linear relationship?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-16-2004, 10:26 AM
mbtoloczko's Avatar
sans SVX
-Bill
On the front suspension, the swaybar attaches directly to the strut body, so the rate of the bar adds directly to the rate of the strut spring. On the rear suspension, the swaybar attaches to the hub, so a coefficient on the swaybar rate may be necessary when adding the swaybar rate and the spring rate. But because the strut is also bolted to the hub, my guess is that the coefficient is very close to 1.
Mychailo
Visit my locker
Old 06-16-2004, 11:09 AM
SVXRide's Avatar
So the 19mm rear bar basically balances out the front and rear spring rates....interesting....
-Bill
Old 06-16-2004, 11:54 AM
mbtoloczko's Avatar
sans SVX
-Bill
Starting to get OT here, but depending on what is meant by bar rate, what you say could be wrong. When I say the 19 mm bar has a rate of around 125 lbs/in, I mean that if one arm is held stationary, it will take 125 lbs to move the other arm through 1" of motion at the link point. When the car is leaning in a corner, if the outside suspension compresses by the same amount that the inside extends, then a rate of 250 lbs/in will add to the outside suspension and a rate of 250 lbs/in will subtract on the inside.
Mychailo
Visit my locker
Old 06-16-2004, 01:08 PM
SVXRide's Avatar
OT? OT? who, me?
Agree on the add/subtract aspect of the bar when leaning in a turn. I now return you to your regularly scheduled thread...
-Bill
