Old 03-29-2001, 10:17 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Well with 102k on my car, i thought it wouldnt not be a bad idea to change the filter on the fuel line. Is it in a place easiely gotten at? Checking subaruparts.com, it dosnt look to diffucult giving the car is jacked up from the back(an experience in itself) It might do me good, my gas mialge sux even after the EGR swap, (that and my flowmaster highflow dosnt like cold weather) Well anyways if any of you have done so please give me a do or a dont. Thanks
~Phil
Old 03-29-2001, 10:23 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
I haven't personally changed the filter, but, it shouldn't be difficult. It's the big shiny "coffee can" looking thing in the upper right hand corner of your engine bay as you look toward the driver's seat from the front of the car. Just make sure you release pressure. Unhook the electrical connector to the fuel pump and crank the car a few times. If it starts, let it run 'til it "dies of starvation." Then, you should be able to change the filter without spraying yourself (and your engine) with fuel.
Randy Johnson
Mike Davis -- at Reading VI
Old 03-29-2001, 11:36 AM
Phast SVX's Avatar
how odd
in the engine bay.......thats a new one....come on, give me a break, im use to workin on my friend schevy's. Thanks for the location/tip randy.
~Phil
Old 03-29-2001, 11:53 AM
Aredubjay's Avatar
D'uh, lemme see dere. Uh, open up da hood and look in da hole what yer motor is in. Den, look up close to da firewall on da driver's side, den just behind da inside of da fender well, and den, maybe youse can see da shiny ting wid two hoses comin' out da top. Uh, dat dere would be your fuel filter, like , ting. So, uh, dere. Is dat better?
Randy Johnson
Old 03-29-2001, 05:42 PM
immortal_suby's Avatar
Thread Killah
I changed the fuel filter a couple months ago and - against my better judgement - followed the advice of a few in yahoo to skip disconnecting the electrical harness and cranking to relieve fuel pressure and instead snap a vise grip on the fuel line during the change. But, it actually worked and I didn't end up spraying raw fuel all over the garage. Just remember that when you take out the old filter it will still be full of gas, so don't tip it over in your engine compartment, instead tip it over in the driveway and light it on fire to dispose of it
Locker Link
2015 BRZ Limited 6MT
Old 03-31-2001, 11:59 PM
cdigerlando cdigerlando is offline
EGR Swap?
What was the EGR Swap?
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 04-01-2001, 12:31 PM
Phast SVX's Avatar
hah funny you ask....
<<What was the EGR Swap?>>
I like to refer to it as the, "swap" rather then replacement becuase it took my dealership THREE orders to ge tthe right part, all at my expense. Infact they installed the first one and said if i wanted it taken out i would have to pay for that too! argh, im not gonna get all worked up over this....ill just stop talking..its the only dealer in a 70 mile radius..
~Phil
Old 04-01-2001, 04:10 PM
Did you remove the EGR?
If you did, I would be interested in the procedure used, and if it messes up the ECU in any way. I don't want to recirculate hot air into my turbo intake. The turbo is enough of a preheater.
Chuck D.
Old 04-01-2001, 09:21 PM
Phast SVX's Avatar
not for sure
I can tell you one thing, my svx was running rich as all hell. I was getting something like 150 mi/tank with in city driving. It didnt seem to damage the car, but you will get the check engine light. My old egr solenoid is stuck closed, if you wanted it i would give it to you for free if you paypaled me shipping charges from madison wi. You could experiment wiht it, but tinkering may be hard. keep in mind it does not open as of now, and your car will run VERY rich.
contact me if you want it
~Phil
Old 04-02-2001, 09:27 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
<<my svx was running rich as all hell. I was getting something like 150 mi/tank with in city driving. It didnt seem to damage the car, but you will get the check engine light.>>
Be careful.
My car was running rich for a long time and my cats got plugged and I failed the WI emmisions test. I had to have new cats put on (after fixing the rich problem) and total for new cats(its illegal to install used cats) was well over $1000
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 04-02-2001, 02:16 PM
Phast SVX's Avatar
ouch
Ya, i git it all fixed. Im not sure how the beads in my cats are fairing, im lucky im in madison and not Milwuakee, we dont have testing done...yet....
~Phil
Old 04-02-2001, 02:40 PM
Lowered SVX
what does the egr valve do?
my car is doing this weird up and down idle thing. when i crank the car in the morning especially but even in the middle of the afternoon or after the car has been driven awhile it does the same thing. i thought it might be my idle control valve (solenoid?), but could it be the egr valve. the dealer told me my mas was fine? help?
"Too much fun to drive!"
Old 04-02-2001, 09:51 PM
Aredubjay's Avatar
Hey '94, try unhooking the battery overnight to clear the ecu. The "up and down" is usually the ecu trying to "find" something. Perhaps it has learned something it needs to forget. That's the cheapest and first thing I'd do. Then, go here to see if any of these match your symptoms.
http://i3.yimg.com/3/65d42580/h/db4fee4c/Engcomp.jpg
Randy Johnson
