Old 06-08-2004, 08:47 PM
Namaah
Power steering leak
When i started my car today i heard this god aweful sound coming from my power steering, it was empty... put some STP into it FOR NOW, can anyone help me wit general info whats the difference between a hose leak and the pump and how much does it run for replacment and all that crap and how soon does it need to be done cause im short on cash TX
Old 06-08-2004, 10:45 PM
First of all you must have had a leak of some sort if it was empty. This could have been a hose or an o-ring that leaked. O-ring leaks are very common with these cars. I don't know if it was a very good idea to put STP in the system, but I would put Transmission fluid in it like it is suppose to have. Run it and then go hard over to hard over on the steering and refil the system. Then I would see if the noise goes away. Hopefully it did not wipe out your pump. I would then try to find the leak. You may need to clean the area first and then watch for the leak. Hope you find it and can get it fixed without having to replace the pump.
Old 06-09-2004, 01:08 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
have you seen any signs
or subtle hints of smoke or smelled anything funny lately?
It could be the small return line on the pass side near
the firewall, (aprox $15 hose) or one of the pressure lines that are long and go under and around the motor for about $150...
Or hopefully just an $2 O ring under between the resevoir
and the pump. Looks for obvious leaks under the car or in those areas. You may want to pull off the lower catch panel too for a better inspection.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 06-09-2004, 12:11 PM
Namaah
i see the leak both dripping under the hood, and some lines all greasy so thats what leads me to blieve its a hose, and no i havnt seen any smoke lately. I had the noise in the steering when it was empty but after i put the fluid in, it stopped and began to leak again (last night). So im assuming that by this time its empty again, ot near empty. Ok ima see what i can do... Thanks again guys
Old 06-09-2004, 12:22 PM
Namaah
Can someone link me off to an O-Ring manual, cause i can find it in the search
Old 06-09-2004, 12:50 PM
Namaah
Oh yeah i see the leak the most on the hose by the wiper fluid resivror, and under... if that helps any
Old 06-09-2004, 01:50 PM
Sounds like you may need hose #
34610PA071 pre-formed hose, not too bad to
change. They usually get a pinhole leak in them
right on the 90 degree bend after about 10 yrs.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
