Old 06-08-2004, 11:46 AM
Warren C Warren C is offline
4 FEAT transmission from a Legacy in an SVX ??
The 4 FEAT automatic was also used in the 90-94 Legacy....
Does anyone know if a tranny out of a Legacy can be used in the SVX.
I have a good one in a Legacy I'm going to part out.
Warren C.
Old 06-08-2004, 11:52 AM
red95svx
Yep, it will work.
Old 06-08-2004, 12:01 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
But....it is not the same. The SVX 4eat is a bit beefier.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-08-2004, 03:16 PM
red95svx
That's true, but you could also argue that the SVX tranny is more prone to failure!
Old 06-08-2004, 03:22 PM
Bolt UP ??
Beefier ....how??
Is it a direct bolt up swap?
Warren C.
Old 06-08-2004, 03:26 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Bolt UP ??
From my understanding, the SVX 4EAT's gears are stronger to handle the bigger torque load produced by our engines.
-Chike
Originally posted by Warren C
Beefier ....how??
Warren C.
2006 Steel Gray WRX TR (sold)
Old 06-08-2004, 03:27 PM
Word to Yo Motha
It will bolt right up. The differences are in the clutch packs. The SVX simply has more. This in part adds to the SVX transmission overheating issues, that is why Dave said it is more prone to failure.
And different gear ratios. You would need to change the ring and pinion in the SVX to match the legacy.
Collin
1995 L AWD
Locker
Old 06-08-2004, 05:03 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
impreza tranny works too
I swapped out a 96 Impreza with 4.11 gears. I used the svx torque converter too. It is bigger/beefer. I have had no problem with the tranny, speedo speed seem correct too.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 06-08-2004, 07:35 PM
Mr. Pockets's Avatar
Moderator
The number of clutch packs is the same - but at least one of those clutches (the transfer clutch) has two more plates. I can't speak for the other clutches.
As for durability, I wouldn't expect it to last any longer. The reason the SVX's tranny fails is that it's undercooled. If you put in a new tranny, but don't improve the cooling, you're just going to run into the same problems. That, combined with the less beefy clutches, doesn't bode well for the Legacy tranny in the SVX. I'm sure if you babied it, you could make it last for a pretty long time. But it's not an even swap for a real SVX tranny.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-08-2004, 10:48 PM
mark10t
Rear of the front differential, the SVX and turbo Legacy tranny's are the same. I just did the reverse- I put an SVX transmission in my turbo Legacy wagon. The final drives are different in all three variants and the ratios are different between turbo and non-turbo Legacy's.
Here's the thread for better descriptions and differences between SVX's and turbo and non-turbo Legacy's:
http://www.subaru-svx.net/forum/show...threadid=18646
If you search, there are another thread or two discussing this further.
-Mark
