Old 04-14-2004, 09:39 PM
JLittell
Door Light Out
My passenger interior door light has been out for months. I checked the bulb and fuses. Anyone know what might be wrong? Electrically everything else is sound.
Old 04-15-2004, 12:43 AM
saintSVX
it sounds like you arent getting power at the bulb, my guess would be a wire got cut. and i dont know how you go about tracing the wires. are the other lights turning on?
Old 04-15-2004, 08:58 AM
Have you checked for power at the bulb? I think you have, but I just wanted to check before I look for information for you.
Old 04-15-2004, 04:19 PM
JLittell
All lights are working as they should. No power to the bulb at all. Wires are not cut as it worked before.
Old 04-15-2004, 05:55 PM
michael's Avatar
michael michael is offline
What Potholes ???
start here
Pop off the door panel and check to see if it came unplugged, it joins right behind the window switches. Check for power there.
Wanted: Steering Wheel
Old 04-15-2004, 07:20 PM
JLittell
Yes I did that too
Old 04-15-2004, 07:46 PM
lee lee is offline
I'm thinking you will need some quality time with a VOM and your wiring harness.
I've not yet read of this on the SVX, but the MR2 guys used to complain the the wires in the door fatigued & broke from too many open/close cycles. Just an idea for a continuity check
Old 04-15-2004, 07:53 PM
JLittell
Does anyone know where the passenger door light wire eventually goes? From what I can tell it looks like into a block of some type under the glove compartment. Could it be on a fuseable link?
