Old 04-13-2004, 08:38 AM
mbtoloczko's Avatar
sans SVX
Originally posted by tmaslar
Alan,
I was hoping you had located your sending unit after the cooler. Now this means I really do have higher temperatures right out of my TC than you do. I was beginning to think that my readings were normal for oil leaving the TC. I am hoping that switching to synthetic ATF will lower my readings a bit. I hope it does not indicate impending tranny trouble.
Tom, Synthetics can withstand higher temperatures before breaking down, but synthetics will not cause the temperature to drop. Try taking out the ATF thermostat. I think that will provide some information about what's happening.
Mychailo
Visit my locker
Old 04-13-2004, 08:39 AM
dcarrb dcarrb is offline
Originally posted by immortal_suby
I think it is kindof like laser warning on a radar detector - if you see it light up you're already screwed.
Well put.
dcb
Old 04-13-2004, 03:14 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
I'd be quite concerned if in this kind of weather I was running at 210-212. 212 is the highest indie. verified flash point for ATF I could find (Mobil 1). After that temp the fluid breaks down very rapidly and no longer does its job. Switching to synthetics really won't affect the temp too much but usually will give you a higher flash point. Since you have normal fluid in there now I'd definately suggest Mobil since it is compatable with any and every fluid out there provided it is ATF II or III. Definately insulate that puppy to be sure your reading is somewhat correct though.
Old 04-13-2004, 04:01 PM
tmaslar
I do plan on bypassing the bypass valve and insulating the sending unit when I can find a free moment. I will be surprised if the insulating the sending unit will make much difference. It seems to me it is already shielded because it is located under the battery and thus has quite a bit of metal (the frame,end of the bumper assembly and a piece of sheet metal)between it and the engine. Although stranger things certianly have happened, so I will give it a try.
Old 04-13-2004, 04:52 PM
lee lee is offline
Originally posted by dcarrb
This thread raises a question:
At what temperature does the AT OIL TEMP warning light illuminate?
dcb
The MY95 Legacy TSB says it comes on at ~ 302F.
So, paraphrasing what immortal said: when it comes on, stick you head between you legs and kiss your.....transmission goodbye.
Old 04-14-2004, 06:15 AM
Wow. And the caution blurb on the driver's sun visor says something like, "avoid hard driving" while the light is on.
dcb
Old 04-14-2004, 07:40 AM
dcb
it should say, "avoid hard driving ON THE WAY TO HAVE THE TRANSMISSION REPLACED" while the light is on.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 05-24-2004, 09:24 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
being in Az
our temps are already over 100 out in May....
after driving around for about 20 min or so in traffic
my guage will hit 215 pretty easily.
I have my sending unit in-line of the Trans
line out of the tranny before the cooler, so I know
what the Temp is of the fluid headed to the cooler
and it will only get better.
Ive been installing my coolers up in the dr side wheelwell
at an angle to get the most air flow and stay protected.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 05-25-2004, 09:11 PM
immortal_suby's Avatar
Thread Killah
I removed the belly pan a few weeks ago and got a consistent 20 degree reduction in tranny temp on a 1600 mile round trip.
I used to see tranny temp during highway driving at very close to 100 degrees + ambient temp (80 outside = 180 tranny) That dropped by 20 degrees throughout the highway portion of the trip.
Not sure yet if it has helped around town - I think there are too many other factors involved to get an accurate assessment. (mainly, my right foot controls the tranny temp in city driving)
Locker Link
2015 BRZ Limited 6MT
