Old 04-07-2004, 03:10 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: With Stock Brake Pads?
Originally posted by svxjoe
Can you use STOCk brake pads with the rotors from RaceConcepts.com?
Yes, given that they're new pads - definitely follow the "bedding in" directions that come with the rotors (they are zinc coated, so you'll be burning the zinc off of the actual braking surface in addition to "bedding" the pads to the rotor surface).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-07-2004, 03:15 PM
svxjoe's Avatar
svxjoe svxjoe is offline
Only SVX @ UCF (Cool!)
Send a message via AIM to svxjoe
Stock Brake pads
Can you use STOCK brake pads with Raceconcept.net rotors?
-SVXJoe
"One day, when I'm all grown up..."
Old 04-07-2004, 03:29 PM
svxjoe's Avatar
Re: Re: With Stock Brake Pads?
-Bill
Thanks for your reply Bill. What exactly does "bedding" the pads mean and how is this done? Or is it done automatically with normal braking after the new rotors are put on? I installed new brake pads for the front almost exactly 1 year ago (About 12,000 miles), and I have new brake pads waiting to be installed for the back.
I'm most likely going to have a local brake shop install these new rotors, so I will have to tell them about the "bedding-in" of the pads and I would like to have an idea of what that is, so I can make sure they do it. Thanks.
-SVXJoe
