Old 03-19-2004, 03:37 PM
The Molinator
Air Cond. Service >>>>
I'm at the mechanic getting my AC serviced (sucking out refrigerant, then filling full). The cross bar in front of radiator shows R - 12, but the fittings and compressor say 134.
My question is: HOW MUCH 134 SHOULD IT TAKE TO FILL? [The R - 12 label says 21 to 25 oz., but the dealer mechanic says around 32 oz. (?)]
Please give me your opinion if you have info about this, THANKS!
Jim
