Old 03-17-2004, 10:42 AM
TonyShaleUK
Front axle shafts the same??
Having had a garage try to fit a 96 front axle shaft onto my 92 car and being told it doesn't fit, Ive just proved it can!
I am having a loud banging noise at low speed on lock, so I am sure it is the shaft. Having swapped the shafts, the noise is still there, so it must be the other side (last time I go to that garage!).
So my question is, are the shafts the same for nearside and offside?
I'm sure that they are, but confirmation before I do another swap would be nice!
Thanks
Old 03-17-2004, 02:43 PM
SVXsnubb SVXsnubb is offline
Re: Front axle shafts the same??
Originally posted by TonyShaleUK
Do you mean with nearside and offside is that right hand side and left hand side?
If so, the shaft are the same type for left and right.
The same cv joint the same lenght and same tread (RH)
Lars
Thanks
lars s
Old 03-17-2004, 02:47 PM
red95svx
Yes, the axles are the same for all years, and they are identical left and right (#28021PA061). The only difference is with the 2WD models.
Old 03-17-2004, 03:29 PM
TonyShaleUK
Thanks all.
Sat may see me back on the road again!
Tony
Old 03-17-2004, 05:50 PM
immortal_suby's Avatar
Thread Killah
What is the difference on the 2wd axles.
I bought an axle from raxles.com and it would not fit in the hub on either side - drivers or passengers. It will go in about 1/4" and then stops. It looks identical.
Locker Link
2015 BRZ Limited 6MT
Old 03-18-2004, 08:45 AM
red95svx
I'm not sure. I don't have any to compare. All I know is that the part # is different.
