Old 03-14-2004, 06:26 PM
svxsubaru1's Avatar
A few 5 spd qustions?
I just got mine running a couple days ago with 5spd, and i have a couple questions.
1. My key is stuck in the igntion, i thought i spliced the right wires but now the key wont come out and the manu light is on, on the dash?
2. I put a high perfromance clutch on it, and the clutch was slipping really bad, it would slip in 2 with any thing more than 1/3 throttle. The clutch seems to be getting better, is this normal( i have only driven the car about 30 miles with the 5spd?
Old 03-14-2004, 10:00 PM
alex_umn alex_umn is offline
I live in a drawer!
Send a message via AIM to alex_umn
There's a switch/pin you can touch underneath the steering column to release the key. I actually took that part out when I replaced the bolts holding in my ignition switch, figured I'd save a little weight that way
Are you using a cable or hydraulic clutch? If hydraulic, does the pedal seem to be springy at all? If so, maybe the lines have air in them and thus need to be bled. Otherwise, the rod that connects the pedal to the master cylinder could need to be adjusted.
Hope this helps...
Front to back, sorta: Claret 1992 Subaru SVX LS-L, JDM STi open front diff six speed, STi tranny mount, Kartboy shift bushings, WRX CD changer, rear R180, battery in trunk, Stebro exhaust.
2000 Specialized RockHopper A1 FS, converted to singlespeed 36:15.
I like my cars with too many gears and my bikes with too few...
Old 03-15-2004, 12:24 AM
svxsubaru1's Avatar
I have a cable operated trannie, seems to be in adjustment.
Old 03-15-2004, 08:12 AM
mbtoloczko's Avatar
sans SVX
Your clutch should not be slipping at all. Is your pressure plate designed to be used with the flywheel you installed? Sounds to me like you are using a pressure plate for a WRX flywheel, but you are using a non-WRX flywheel (or vise versa).
Mychailo
Visit my locker
Old 03-15-2004, 09:42 AM
svxsubaru1's Avatar
No i am not using a WRX presure plate, the clutch was specificly designed for the trannie, flywheel i am using. The clutch comes with a breakin procedure says to drive around for 400 miles with out flooring it around, maybe it needs tobe broken in, or the flywheel could of maybe have some oil or something on it?
Old 03-15-2004, 11:33 AM
mbtoloczko's Avatar
sans SVX
I can't imagine that the clutch disk could initially be so slippery that it would be easy to make it slip.
I guess I'm saying the obvious, but my guess is that one of two things; either the pressure plate is not applying sufficient pressure, or you somehow got some sort of lubricant on one or more of the clutch friction surfaces.
Mychailo
Visit my locker
Old 03-15-2004, 11:53 AM
GreenMarine's Avatar
From POST-***** to LURKER
Re: A few 5 spd qustions?
I can help ya with the key thingie... If ya wanna call me later on this afternoon (after 5:00pm but before it gets dark) then I can tell ya exactly what ya have to do... I'll even go out to my car and describe what I did to mine to solve this... Hope to talk to ya today!!!
if ya don't have free long distance just call me and I'll call ya back... Later!!
(843)321-2363
Old 03-15-2004, 12:06 PM
svxsubaru1's Avatar
Your in the Eastern time zone right?
Old 03-15-2004, 10:01 PM
svxsubaru1's Avatar
Thanks alot GeenMrine SVX for the help Also my clutch seems to be getting better, i can get 90% throtle in second with out slipping.
Old 03-16-2004, 05:15 AM
I know you said you thought your cable was adjusted right, but try loosening it a little any way, the cable should have at least a 1/2" of free play in it, if it's taunght, then it's to tight.
It shouldn't slip....if it's getting better, it's because you've worn it down to match the setting of the cable, not good...try adjusting it some more
Old 03-16-2004, 06:02 AM
you cable clutch guys .... j/k... I like Hydrolic... Even though it is more complicated and all that stuff...
Old 03-17-2004, 05:05 PM
svxsubaru1's Avatar
The Clutch does not slip at all any more, it only sliped a couple of times in the first place, but got progresivly better, maybe there was oil on the flywheel. Yeah i have about .5-.75 inches of pedal free play before it starts pulling on the cable. I floored it in 3 and the clutch did not slip at all . Thanks for all the responces.
Also if the cable was taught and was pushing the through out bearing wouldent it only get worse.
