question about transmission
I have a question about my transmission. Last fall my tranny started to act up and I decided to park it until spring. Heres what it is doing when I first start it up it goes into all gears but after about 2-3 minutes no movement in any gear and I car hear a slight sucking noise. What could this be a clogged filter or a more serious problem. I changed the fluid but could not change the filter in the pan due to a hard line that goes over it. I could not remove this line or get the filter out What is this line for and could a clogged external filter cause this problem. By the way my SVX is a 1992 LSL with about 112000 miles: Thanks for any help you might have. Damian
Yes that line is difficult to pull down. I had the same problem and left it alone and then the next time I pried it out. It is possible your intake screen (not really a filter) is clogged and good to check. This will tell you if it is the problem. I think you should change the external filter too.
Oh yeah that line that goes accross the intake screen, I rememeber janking on it so hard I had the svx bouncing up down 6 inches while it dripped AFT fluid all over me. Pry it out after the screws are removed. I think a pressure test may be in order if you find nothing obvious with the filters.
thanks for the info.I felt like ripping the line out myself after having no luck with it. Thanks Damian
slow engagement
I experienced the same symptom w/my last tranny too. The FSM says that 'excessive time to engage is highly likely to be a deteriorating pump gasket'. There is a TSB about this and a part # for the replacement METAL, not FIBER/paper gasket. Good luck!
mile-hi-bri - Brian |
