CE Light
Some help please. Okay so my CE light keeps coming on. I tried to check the code but when I turn the car on the CE light dose not flash like the thread that Lwin wrote said it would. Has any one else had this problem with a 94 LS? I could really use some help on this one.
CE light doesn't blink to indicate a problem, it blinks when you do a "d" check. If it sees a problem it will come on steady.
Do a search on how to do the d check. Lwin
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
More than likely, once you've translated the codes, you'll find you've got a bad oxygen sensor. It's a common problem.
Thanks
Thanks guys will do that on my next day off.
Pull my finger! |
As far as suggesting that he probably had a bad O2 sensor...when mine was coming on, it was the knock sensor.
Pull my finger! |
