Old 05-02-2011, 01:53 AM
zaueugen's Avatar
zaueugen zaueugen is offline
minor noise coming from wheels when driving??
a had really worn out bad rotor on the rear right and i could hear a rubbing grind coming from it.. i changed the rotors on the whole car and still hear a slight rubbing grind sound when i drive.. sounds like its coming more from the the right rear side, not sure what it might be. any inpput please. thanks
Old 05-02-2011, 03:18 AM
Re: minor noise coming from wheels when driving??
Check the dust shields and see if they are touching the rotor or something.
Not wheel bearings right?
Old 05-02-2011, 03:32 AM
Dessertrunner's Avatar
Jack the car and rock the wheels to see if its the wheel bearing. I also agree with dust shields either way you need to jack the wheel up and check. One last though is has the plastic shields inside the wheel well come lose.
Tony
Old 05-02-2011, 04:11 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
I have a similar problem and in my case, I believe it to be both a loose brake calliper and also the dust shield touching the brake assembly. You could check the calliper for rattles.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 05-02-2011, 08:25 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I also have this issue. Im going to assume its the shield cause its an easy fix.
Old 05-02-2011, 01:14 PM
zaueugen's Avatar
i checked it out and its the dust sheilds i beleive, how should i fix this?
Old 05-02-2011, 03:26 PM
Bend them back away from the rotor. They're pretty soft, so they bend kinda easily. Be careful not to damage anything by prying at stuff. You probably can do it by hand, but if you have to use something to pry them away, don't overdo it.
Old 05-02-2011, 11:37 PM
AlcyoneHakase's Avatar
AlcyoneHakase AlcyoneHakase is offline
(^・ω・^)b
If it isn't the dust shields it might also be the parking brake shoes not fully disengaging and dragging a bit.
Old 05-03-2011, 12:42 AM
zaueugen's Avatar
my parking brake (handbreak) doesnt even work... so it might be that, because the sound is coming from the back wheels. but ill try to bend the plates back this week see if the sound countinues..
