brake bleeding problem
Has anyone ever had any trouble getting fluid to come out of the bleeders. my left front and right rear brakes wont bleed. I cant get any fluid to come out and i have very little brake. The shop had it and tried to bleed them first and said that they would have to start taking lines off and do the process of elimination. I tried bleeding the bleeder on the abs unit (wich the shop didnt do) and got just a drip of fluid to come out then it dried up. The shop sucked out all the old fluid because someone had put motor oil in it. My buddy told me that when one goes dry that there is a pump that you put on it and get fluid going again. It is a self bleeder or evacuation pump. Anyone have any ideas. I am figuring maybe a stopped up line or collapsed line but since it is the LF and the RR (wich are both on the primary bleeder on the abs), maybe it is something else since these two run together. Any help would be appreciated. Thanks.
Re: brake bleeding problem
Never put anything but approved brake fluid in your braking system. anything else can cause sudden brake failure! Any other type of oil or fluid will react with the brake fluid and very quickly destroy the rubber seals in the brake system, causing brake failure. Contamination With Petroleum Products: “Petroleum products are rapidly and selectively absorbed by brake system rubber parts, resulting in a high degree of softening, dimensional swelling, and general deterioration of the functional properties of these rubber parts. This type of brake fluid contamination will result in unsafe braking action and may be the direct cause of complete brake failure.” For more information , click HERE The steel brake lines won''t need to be replaced; however, they will need to be adequately flushed to remove traces of motor oil, as motor oil will swell the rubber parts in a brake system. I'd recommend replacing the wheel cylinders and the calipers (or at least rebuilding them) and flushing the brake system. Not to sure about the rubber brake hoses or the ABS unit. Flushing with denatured alcohol will remove any residual motor oil. Working, non-contaminated ABS units and master cylinders should be available on the network .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-12-2010 at 08:01 AM. |
Thanks man. I found an abs unit off of svxfiles if needed. I hope nothing major was messed up but it dont sound good.
Just to let everyone know, my problem was the master cylinder. Thanks guy and especially svxfiles. Everyone is a lot of help here. Hope to get the suby on the road soon!
