Headlight Restoration (warning 56k - heavy pics)
Main Album Link: http://www.facebook.com/album.php?ai...&id=1479900008
I chose to clean up my headlights today. My uncle gave me a 3M kit for Christmas, so after I purchased some clear coat and a nice day came up, I went to town. The kit gives you a couple 500 grit pads, a couple 800 grit pads, a 3000 grit pad, a foam thing for polishing/restoration (and some restoration polish), and an adapter to fit your 1200-1400RPM drill. I was committed to clear coating, so I taped and newspaper'd the crap out of the front of my car and did not use the foam thing/polish. Between each grit pad, I wiped down the headlights with a wet rag. Only the 3000grit called for wet sanding (very light wet; just a spray bottle). The headlights are pretty beat themselves so no amount of sanding is going to make them perfect, but I think they're much better now than they were before. Total time: I started around 12:15 and started with clear coat at 1:45. It says 15 minutes per lamp; I guess I'm a little slow. Here's the kit: Here's the clear coat I got at Wal-Mart: Here's what they look like before: Here's what the driver's side light looked like after I took the 500grit to it: Here's what it looked like after I took the 800grit to it: Here's what it looked like after I took the 3000grit to it: Here's what it looked like after 2 coats with the clear coat. I was going to do three, but it started to run so I decided that was enough: And the left side light with the lights on:
Re: Headlight Restoration (warning 56k - heavy pics)
I was looking at that very kit yesterday. What is your verdict on it?
Does anyone have alternative products they would recommend?
Instead of buying the kit I did mine with 1000grit, 1500grit, and 2000grit wet sandpaper from an autopart store. For polish I used some 3m plastic polish we had at work.
See Post #33 in this thread for pics of it: http://www.subaru-svx.net/forum/showthread.php?t=54507 First time I did my lights I used "Mothers mag and aluminum polish" instead of sandpaper and polish. It worked ok for taking most of the yellow off. ' Pics here: http://www.subaru-svx.net/forum/show...2&postcount=12 |
I have mentioned it before but I did my tail lights using a micro mesh kit. Google it. Fantastic stuff, i highly recommend.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
The headlights are glass and the taillights are plastic, correct? Or are the headlights plastic too? They feel like glass.
No, unfortunately they are both plastic.
Its looks verry good. But i have a little qvestion. What are you useing this for? Before or after?
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
I think if you're a good rattle can sprayer then you can get one three coats without it running. I'm not very experienced, so after 2 it started to run a little.
