Old 07-12-2010, 10:57 PM
Nevin's Avatar
Nevin Nevin is offline
did some work to my daily driver
Well, I finally got the mx6 running like I wanted it to and I cleaned it up the other day. Unfortunately I only took pictures of the motor.
But we all know that's the only thing that matters anyway.
Forgive me for only having my camera-phone. It does a good enough job to get the point accross.
Ahh, a clean f2t.
Accessories? Pffffttt, who needs 'em.
And the snail that's running the show.
Turbo comparison: new turbo on left, old AiResearch t3 in middle, stock turbo on right
Notice also that there is not a fan behind the radiator. The turbo wouldn't clear the stock fan, a slim fan, OR a hacked up slim fan. I ended up running double pusher fans in front of the radiator and so far it seems to be working very well. City traffic + 90* temps = right below the "M" in temp. Other than that, it's always under the halfway mark. Also of note is that the radiator is a one-off that I had built a few years back. It's a custom 3-row built into the stock copper/brass 2-row shell. Overall it's about 1/2" thicker than the stocker, and it works very well.
The turbo? Well, I honestly have no idea what size it is, and I really don't care. hahaha I'm not trying to break any land speed records, and my old turbo was shot, so I just typed in "t3/t4 turbo 3" inlet" on shmeebay one night and ended up with this puppy. Does a great job though. 10psi puts on speed like crazy, and I believe I can run about 16-18 through it on this motor. AFR's are looking good with the wideband, and I got it to idle pretty solid even with the 460 injectors on the stock (albeit chipped) ECU.
Here's a picture of the car, if you're not familiar.
Next mods are:
1. K-sports are ordered and on the way
2. SS brake lines need to go on + fluid flush and DOT 4 brake fluid.
3. MSD 6a sitting in the trunk
4. maybe make a grounding kit to help these old 80's electronics work a bit more efficiently
5. who knows what else... I'd like to get a set of old 240z fender flares like I've seen on another white mx-6, although I can't recall whose at the moment.
Anyway, just thought I'd share. I'm just happy that it's running well now, and you so rarely see pictures of nice looking mazda f2t motors. I just felt compelled to share mine.
Perhaps you don't know a lot about these cars, but they're fun to work on, pretty reliable, and make gobs of torque for pretty cheap! I only paid $625 for the car, and have been tinkering with it ever since. I would guess it to be in the 200-ish hp/250 tq range at this boost setting, with capabilities of around 270 hp/350 torque as seen by other mx6er's. The current record is 352 whp/ 456 wtq on the stock bottom end. Not to shabby for a 12 valve 2.2!
Thanks all for checking out my car.
Jesus is the remedy
2015 Expedition EL Ecoboost
Ebony Pearl '95 Subaru SVX LSi
Home of the Bontrager Works 22mm rear sway bar!!
Old 07-13-2010, 07:30 AM
Mike621 Mike621 is online now
Re: did some work to my daily driver
The car looks great! I've never seen one of those in such good shape.
Old 07-13-2010, 09:37 AM
subeman90's Avatar
Soobologist
I drove one of those once and it was a great car. It was a 4dr so it had the "sleeper" thing going for it too. Nice looking engine and nice snail too
15 OBW premium w/eyesight
Old 07-13-2010, 11:38 AM
Nevin's Avatar
If I could find a 626 GT with a bad motor, I'd so swap all my parts over to it and drive it in a heartbeat. Ultimate sleeper right there. There was an automatic GT 626 in town for a while, but I don't know what became of it. It was also not in the best of shape.
And I'm trying to keep it in good shape. I'm kinda in the process of a "resto-mod" cause it does have some rust, but I'm going to fix and modify at the same time. Chassis-wise, it is still very solid though. These are already rare cars as-is (mine is 1 of 1200 AWS cars sold in the U.S.) but I know in a few more years it will definitely be old school cool!
These cars are similar to the SVX in that they also don't have a big market, but being factory turbo cars, their potential is WAY higher for cheap. It is fun to make everything that is on the car though. I can honestly say that mechanically there isn't anything I myself can't do to the car. I even ported my own head and re-lapped the valves. And in my book that is just good, clean fun. I haven't put together a bottom end yet, but the main reason I like to stray from that is just because I don't have the tools.
Jesus is the remedy
Old 07-13-2010, 02:07 PM
subeman90's Avatar
Soobologist
AWS= AWESOME!!!!!!!!!!!!!!!!
I drove a Prelude with that once. I was doing circles around a concrete median. it was fun as heck with the tight turning radius. I even opened the door to watch the tires in the back move as I did it.
Old 07-13-2010, 02:57 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Nevin,
Looks like you're swapping rims/tires between cars (?)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-13-2010, 04:49 PM
Nevin's Avatar
Good eye, Bill. All 3 of my cars have the same bolt pattern, but the mazda has a wider hole so the slipstreams don't fit it, but I do have 2 sets of rx7 rims with two different sets of tires on them. Gunmetal's with 225's and blackies with 245's. I decided to go with the black rims and wider tires this season on the mx6, and I really like how they look. It looks like it could have been a factory rim, and realy just makes the car look tough with a 245 tire. Factory was 205/55r15 in GT AWS trim. Now sporting 245/45R16's. Much grippier! haha
And yeah, the prelude is the only oher FWD car I can think of to have AWS. Except there's was not as well engineered and did not have a "fail-safe" incase of mechanical failure. I've read a couple stories about guys going sideways down the road at 70 when the AWS went out!
Jesus is the remedy
Old 07-14-2010, 02:10 AM
alltrac alltrac is offline
Post Re: did some work to my daily driver
I have a 90 PGT it had 3 broken manifold studs so I replaced them with OEM parts and Nord-Lock washers. New OEM manifold and a new IHI center section. I'm surprised you don't have a Dutch FSTB
Victor
Old 07-14-2010, 11:32 AM
Nevin's Avatar
FSTB? Psh, I could really care less to have one of those. And besides, if I wanted one, do you honestly think I would BUY it when I could just as easily fabricate one? hahah
I've broken a few studs too in my day. Last time I replaced with stock ones, but this time I decided to do 10mm studs instead. MUCH heftier.
And get rid of that VJ11 and get a REAL turbo. haha That picture is larger than life-size!
Jesus is the remedy
Old 07-15-2010, 05:54 PM
Shocker33 Shocker33 is offline
nevin....once you get over 15 psi on these mazda motors they will start pushing oil outta the head gaskets......don't ask me how i know this lol......drove a bone stock 89 mx6 all through high school then a 90 gt turbo through college...played with a boost controller a little too much. I envy you're aws car, always wanted to mess with one. All in all I loved driving my mx's they were a riot.
Old 07-15-2010, 08:50 PM
Nevin's Avatar
In my experience, I have to disagree. I've been running these motors for about 7 years now, and have never had that problem. They are VERY stout. I even ran a stock turbo at 23 psi for a bit with no problems! Talk about RIGHT NOW torque. hahah
Plus, mine has ARP head studs... Turns out they're even cheaper than factory replacement head bolts!
Jesus is the remedy
