WTB: Bad Headlight Bulb Pair
Guys,
I am trying to adapt a set of HIDs to the beast. My goal is to do a clean and easily reversible install, therefore I'll need a handful of bad headlights so that I may take the plastic "twist portion" from them and adapt it to the HID bulbs to allow me to twist them in like stock ones. Have you recently replaced your bad bulbs? Even if you have a single bad one, I'd love to pay s/h to have it/them...! Thank you in advance, please let me know. -Walter
1995 SVX Green - now 5spd! ..::|SOLD|::.. 1991 Talon TSi AWD (~400 whp pump gas) 1993 Civic CX Hatch (daily driver) 1999 Ducati 748S (built 996 engine) Last edited by Treppiede; 03-12-2009 at 09:21 AM. |
Re: WTB: Bad Headlight Bulb Pair
My HID setup seems pretty easily reversible to me...? The bulb had the stock fitting and locks right in to the headlight, the ballast connect to the stock wiring, and there are a couple screws holding the ballast in place. I could have mine back to halogen bulbs in 5 minutes.
You purchased a kit specifically made for the SVX, correct?
I am trying to fit an HID kit from an Infiniti G35. I am planning on cleanly cutting the two extremities from bad SVX bulbs so that all I am left with is the screw-in section and gasket. I will then dremel out the inside of the plastic piece so that I can insert the HID bulb in it. Once fitting is satisfactory, I will glue the HID bulb to this new "adapter" and make it a screw-in affair. If you can think of any easier way to do this, by all means let me know. My main goal is to keep it clean and reversible. Thanks! -Walter
1995 SVX Green - now 5spd! ..::|SOLD|::.. 1991 Talon TSi AWD (~400 whp pump gas) 1993 Civic CX Hatch (daily driver) 1999 Ducati 748S (built 996 engine) |
Why do you want to use the Infinite kit?
Because I already have it.
-Walter
...anyone?
-Walter
Just head to Wally world and pick up the cheapest set of 9006 bulbs. Shouldn't be more than $10 bucks for both. Shipping for a pair is gonna be about $5 or so anyway.
why waste your time doing this. just sell the infinty kit and buy any 9006 or 9005 kit depending if you want lows or highs. they will fit the svx and they are incredibley easy to install.
Nate: I don't know, but for some reason I hate the idea of breaking a perfectly good set of bulbs. I guess living in Europe for ~20 years molded me into being less prone to waste.
Keoni: It's not as hard as it may seem. The hardest parts seems to get a set of bad bulbs. -Walter
Edit: found another bad one. Any clue on what to put these in for shipping that would be the cheapest? Last edited by 1986nate; 03-14-2009 at 09:26 AM. |
never said it was hard... just seems like a waste of time
Thanks Nate... if you could send them out USPS Parcel Post it would be great... PMed you with more info.
Regards, -Walter
