Old 06-05-2001, 08:55 PM
KEVINL
Unhappy Tranny problems need help
Okay this is a long shot but I'll try it. okay my SVX has a problem with its transmission It goes into Nuetral Reverse and Park fine when you put it in Drive it stars out in third and when you put it in first it loads the engine but nothing happens and then all of a sudden it will go into third and try to go back into first and bind up and actually stop the car. like its in 2 gears at the same time. We changed the valve body and tried the 2 computers from a SVX that was fine. and that didnt help. We still believe its the electronics and not tranny because it feels like the computer cant figure how to put it in gear. I also have the resistor unplugged but plugging it in changes nothing. Could it be in limp home mode. If so how do you get out of limp mode
sorry for the long post
Old 06-05-2001, 10:11 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Kevin. You're not getting any codes from the TCU? That makes it tough. The "trouble possibilities" in the manual covers two fold out pages with very small squares and x's in the possible "culprits" columns. Many of your symptoms point to a bad control valve, but there are MANY possibilities. However, if you aren't getting any codes, it could more likely be mechanical than electronic. If there's a mechanical problem, it will not register in the TCU diagnostic. (I'm just thinking out loud) Damn. I need to scan the general trouble shooting chart for the tranny (I did the one for the engine). I'll do that one of these days. Sorry I'm not much help.
Randy Johnson
Mike Davis -- at Reading VI
Old 06-06-2001, 01:37 AM
eddycat2000's Avatar
eddycat2000 eddycat2000 is offline
Dumba$$ Mechanic
The planetaries have fried.
Pull my finger!
Old 06-06-2001, 06:17 PM
Aredubjay's Avatar
Ouch!
Randy Johnson
Old 06-08-2001, 12:55 PM
Lowered SVX
damn eddy.....
that was so harsh it nearly brought me to tears.....my planetary fried....oh god the pain! but when my planetary gear fried it drove but there was just a super loud clunking, rattling, vibrating noise. it was straight up horrible and i never want to hear that sound again!
"Too much fun to drive!"
