Old 04-10-2008, 08:44 AM
Originally Posted by AndrewR View Post
Actually.. The head gasket issue we finally resolved by Subaru late 2003 with another revision of the gasket.
I had a 2000 and a early 2003 that the HG went on. The Phase 2 blocks leak externally vs the phase 1 internal leaks though.
The 2000+ has a stop leak additive that stops most head gasket leaks as long as it is added with every coolant change.
Yeah they used paper gaskets, then changed to the composte gaskets like the SVX has, then changed to 3 layer metal gaskets.... Silly Subaru trying to cheap out on HG's
Old 04-10-2008, 09:28 AM
I was going to mention the later models had the HG issues too, but you guys beat me to it!
Definitely should put a timing belt on it and do a basic tuneup I think.
Old 04-10-2008, 09:30 AM
That'll be fun..... to watch
Old 04-10-2008, 09:31 AM
Almost as fun as seeing you crash things into trees...
That WAS FUN!!!!
Old 04-10-2008, 09:32 AM
I try to keep the car off a "crash course" with nature. This OB will have Limited time off road.
Old 04-10-2008, 09:52 AM
can I drive????
Old 04-10-2008, 09:54 AM
The "if Tom can break it, you should have replaced it" Test also known as "GUN"
Old 04-10-2008, 03:37 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Originally Posted by TomsSVX View Post
That WAS FUN!!!!
I was laughing so hard i couldn't breath, but i couldn't stop laughing. It was quite fun.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-11-2008, 08:08 PM
Update:
I called off the entire transaction because the seller tried to hide the fact that there was a head gasket leak by changing the coolant and the oil, but it did start mixing once running for 5 or 10 minutes. I offered to buy the car for $1250, issues included, but he wouldn't move from $2000 so I walked away from the deal.
Old 04-11-2008, 08:51 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Update:
Mike,
Can you post up the seller's eBay name so we can all stay away from him?
Thanks.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-11-2008, 09:06 PM
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
Ebay userid: "raymondsingh"
Old 04-11-2008, 09:46 PM
SVXRide's Avatar
Car - Brooklyn =
I take it he's getting a negative rating from you?
-Bill
