Old 08-08-2002, 12:17 PM
sith
Metallic noise going over bumps
So, heres a new one... just noticed it today.
Going over bumps (even small ones, various speeds), I hear a very distinct metallic noise from the passenger side. It's best described as the sound of change rattling in someones pocket. Chi-ching. Sort of like a tamborine sound. I can't notice it with the windows up, but it's very pronounced when the windows are down. Did an initial look around and couldn't find anything out of place...
Anybody have ideas?
-Colin
Old 08-08-2002, 12:20 PM
Earthworm's Avatar
Meow!
most likely something in the brakes. (shims perhaps)
Old 08-08-2002, 12:58 PM
mattski mattski is offline
Going over the bump, lightly press on the brake pedal. If the rattling goes away, it is likely to be the pads rattling in the caliper. When pressed against the rotor, the ralltling stops. If that is the case, then replacing the shims (and pads if needed) should help.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 08-08-2002, 01:36 PM
sith
Hmm... noise doesn't seem to go away while braking.
I'm pretty sure it's coming from rear (passenger side)..
Any other thoughts?
Old 08-08-2002, 01:54 PM
Loose heat shield around exhaust system? Shake the muffler and see if you hear anything.
Mattski
98 Outback 180k
Old 08-16-2002, 02:03 PM
sith
Had the dealer take a look... turns out the noise was an adjuster spring that had come loose in the brake assembly. They put a new spring in and the noise is gone. Hoorah.
-colin
