Old 12-30-2006, 10:54 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Happy Holidays
Happy Holidays to all and to all a happy and prosperous New Year. For those I've met in person, Bill, Tom, Tom, Mike, Mike, Eric, Chike, Harry, Ben, Dave and Todd, and others, and for those with whom I've had spirited elecronic discourse, Electrophil. Trevor, Harvey, Earl, Earthworm, Danny, Ricochet, Michael, many others, and, not least, Lee, thanks for a terrific botherhood and sisterhood, Diana. Hope to communicate with all and see some of you in this upcoming year as we mutually and severally pursue our sometimes frustrating common obsession, our SVX's.
Dan
Old 12-30-2006, 01:56 PM
Happy New Year to you as well. Hope this one is good to you and your SVX.
