Old 10-31-2005, 11:28 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Lash adjuster
Is the lash adjuster something that can be replaced without pulling the engine? How hard is this job? I've got a bad tick.... I tried pouring liquid Prozac in the tank, but the tick remains.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-31-2005, 11:34 PM
mbtoloczko's Avatar
sans SVX
The lifters are hydraulic, so no lash adjustment. You could try some oil detergents.
Mychailo
Visit my locker
Old 11-01-2005, 12:13 AM
Then I replace the lifters?
Robert
Old 11-01-2005, 07:28 AM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
No try an engine flush first...I know at valvoline its $15 with an oil change...basically they are dumping in something that smells like kerosenne in let the engine run for 5 mins and then change oil.
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 11-01-2005, 07:43 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Try a heavy dose of MMO. Older Sooby engines love it. Ben has had good success with something called "Valve Medic"
Old 11-01-2005, 07:48 AM
Mmo?......
Old 11-01-2005, 08:00 AM
I think I'm going to give that engine flush a try. I've tried the Valve Medic, which quietens down, but it doesn't seem to last too long. I have no idea what mmo is..
Robert
Old 11-01-2005, 08:27 AM
mbtoloczko's Avatar
sans SVX
Marvel Mystery Oil. It a motor oil additive. Been around for many years. Probably some type of detergent/solvent.
Mychailo
Visit my locker
Old 11-01-2005, 09:10 AM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
adjusters can be changed w/out removing engine but ...
On my Sub's the best thing to kill the lash adjuster tic is Risilone (yellow quart bottle). I added a quart at every oil change for 40,000 miles before I changed the VLA's (lifters, cam followers, etc). I also found that 10w30 works best in winter and straight 30w in summer.
To remove the lash adjusters you have to remove the timing belt, cam shafts, rear timing cover, valve covers. It's not a difficult job just time consuming and I'm sure a real pain considering the clearance around the valve covers/cam towers.
Try the MMO and Risilone first (not at the same time).
Old 02-14-2006, 03:13 PM
Bringing an old thread back to life...and saying Incidentally...
This worked! I had an extremely bad tick on the driver's side. I could hear it with all windows rolled up and a greyhound bus next to me.
I did the flush, and it was like a miracle. Evangelistic preachers tried to get my car in their show, the difference was so great.
If you have a bad tick. Do this first. But it wasn't $15. It was $49.95. Along with the synth. oil, I spent $110 on an oil change.
But it was better than over a thousand for a lifter job with the same results.
Robert
