Old 01-26-2006, 07:41 PM
crimsonnblue
winter brings out the worst.....
I have a few questions for you people on here that are good with determining what sounds are what. When I turn my car on in the morning (30degrees out) my car makes the old shrieking car noise. I get this noise sometimes when I turn my steering wheel far. Power steering??? Anyways that goes away after 5 or 6 seconds. Then when my engine begins to get warm I hear a whistling noise coming from the other side of the firewall. I have a gut feeling this has something to do with the throttle body.... and one last noise... Sometimes when I accelerate I hear light knock knock...
Any help would be greatly appreciated.
Old 01-27-2006, 10:30 AM
intelisevil's Avatar
<<<Alcyone
Power steering fluid level? Slipping belt? Do the lights dim? Alternator and power steering pump are on the same belt. Replace the power steering o-ring? http://www.subaru-svx.net/photos/files/How-To/14304.pdf
Sorry, no suggestions.
Defective knock sensor? Are you using Premium fuel?
Good Luck!
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 01-27-2006, 10:36 AM
mbtoloczko's Avatar
sans SVX
The knock, knock sound is likely the hydraulic lifters. Its very common and is not a problem.
Mychailo
Visit my locker
Old 01-27-2006, 10:37 AM
Make sure your belt is tight. Mine doesn't make "cold belt noise" until temps hit below zero.
It squealed all summer though because I trusted someone else to tighten it and it wasn't tight at all.
When your car is warming up get out open the hood and look around. Whistling is uncommon.
Old 01-27-2006, 10:56 AM
dcarrb dcarrb is offline
Not sure what you mean by "the other side of the firewall," but if it's something you hear from the driver's seat eminating beneath the glove box area, and your climate control system is on, it's probably the heater fan coming to life. Mine whistles like an old steam radiator as the car warms, unless I manually set the fan speed to low.
dcb
Old 01-27-2006, 11:34 AM
<<<Alcyone
If you hear the "knock, knock sound" only on acceleration, I would think it's 'detonation' caused by poor fuel, bad timing, bad knock sensor, etc.
If you hear it at all engine speeds and it varies according to engine speed, I would agree it's a lifter noise.
My Teal is quiet when I first start the engine on a cold morning, (when the oil is nice and thick). When the engine warms up and the oil thins the ticking starts. Nice slow melody at idle, rising to a crescendo as I accelerate.
Dan
PWR Radiator!
Problems:
Old 01-27-2006, 11:35 AM
dwd1985 dwd1985 is offline
What about a vacuum hose for the whistling noise?
Old 01-27-2006, 12:20 PM
That's more of a wheezing/runny/gritty sound. I guess they would whistle if they had holes in them..
Old 01-29-2006, 02:11 PM
crimsonnblue
It happens when going relatively slow(10-15 mph) and yes I get the same sorta noise with what you described in the morning with light ticking.
So I guess guess Ill check the belt, and try to figure out where the whistling noise is coming from. Also I whisling noise is consistent with my rpm speed. For example when Its at 2500 it is really high pitched and when its lower it is less high pitched. And when I idle sometimes you can hear it but not usually. I think it may be a vacuum leak, but when this winter started I had that checked I guess Ill mention it to my mechanic again. This winter Ive had some idleing, stalling issues.
Thanx for you help guys, let me know if you have anymore suggestions. Oh and Ive always premius gasoline, and for another note, I use synthetic oil...
