Old 12-21-2005, 08:58 PM
nysvx10 nysvx10 is offline
Cranky Pulley
Question about the crank pulley. Mine is making a clicking noise and is wobbling slightly. I removed the belt to see if it had separated, but I could not remove the pulley from its center...But it did spin independently from the center and crankshaft. I'm pretty sure this is not supposed to happen. I think I am going to replace it with the one piece pulley from Motorsports. They DO have a oem size one that takes the stock belts, correct? Is it pretty easy to remove the center bolt and replace the pulley or is more work involved? Should the car be parked until repaired?
PS. This is the second pulley thats been on the car, first one separted and fell off when driving.
Caleb
Old 12-21-2005, 09:10 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
This thread is a good read on getting the crank pulley off.
http://www.subaru-svx.net/forum/showthread.php?t=30237
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 12-21-2005, 09:51 PM
Originally Posted by nysvx10
Mine is making a clicking noise and is wobbling slightly. I removed the belt to see if it had separated, but I could not remove the pulley from its center...But it did spin independently from the center and crankshaft. I'm pretty sure this is not supposed to happen. Should the car be parked until repaired?
Caleb
Do not drive it or run the engine!!!
A 5 pound weight spinning at thousands of RPMs can cause a lot of damage.
Old 12-22-2005, 01:11 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
DO NOT DRIVE IT! I've been through something similiar and trust me, you don't want it to be any worse than it is. Check my locker for pics of the chaos. here's the thread about what I went through.:http://www.subaru-svx.net/forum/show...t=WTF+happened
Good luck.
Old 12-22-2005, 05:34 AM
dcarrb dcarrb is offline
That's what I'm running. Be aware that some knowledgable folks aren't too keen on replacing the stock pulley with a one-piece unit, as you lose any "harmonic balancing" effect the former provides. Scan the many threads on the subject so you can make an informed decision.
dcb
Old 12-22-2005, 05:39 PM
Would anyone be able to scan the pages from the service manual related to removing and installing this pulley?
