Old 12-12-2005, 11:40 PM
neptue's Avatar
neptue neptue is offline
Using crank power on a crank pulley nut?
That's a challenge.
Are you really sure this will work?
I'm kindda scared.
I don't know, I'm not that brave to put a bar in front of the engine and
crank the engine to loose a nut.
I might break other things under the hood.
Any other suggestion?
By the way, which crank pulley is good for replacement?
I guess I'm changing the pully too.
I already spent $750 on buying parts for this job.
This car better be last long! at least 200K mi.
Anybody changed a front seal and a o-ring at oil pump?
My next step is to replace a front oil seal.
Another challenge!
Originally Posted by intelisevil
Can't you just hook the battery up backwards?
Dan
Old 12-13-2005, 12:02 AM
Dan
That could be exciting!
Old 12-13-2005, 12:16 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Dan
No, No, No, No, no...
That's not right....
You have to turn the car upside down...
Old 12-13-2005, 12:57 AM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
i did the breaker bar thing and everything went smoothly... no problems... broke loose before it could even think of goin crazy on somethin in the engine bay
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 12-13-2005, 01:09 AM
neptue's Avatar
OK!
Now I'm confident that I will try break bar method.
I guess several people already tried and I will update the result.
Is anyone have any thought on crank pulley?
Which one is good for replacement?
One thread talked about high rpm problem on
light pulley.
Do you have any trouble using light weight pulley?
Thanks.
Old 12-13-2005, 02:33 AM
Sixpack Subaru
Yeah plenty, If I'd have know I could buy one for that I wouldn't have bothered making one. (We just went through this .....'somewhere...?).
I would ALWAYS prefer to use the pulley spanner/wrench. Less room for error. Is it Sykes-Pickavant, (not sure on the spelling),? Kent-Moore?
cheers. BUY IT!!
Old 12-13-2005, 02:35 AM
Sixpack Subaru
GFB make pullies for subaru's that aren't too bad, just stay away from they're BOV's once you fit you turbos!!
Do a search GFB-Go Fast Bits...Aust based but I believe they have agents over there, (I used to be one!!)
cheers
Old 12-13-2005, 05:27 AM
Sorry, for being slow to reply,
But yes, I have used the breaker bar method many times, I even use it on the cam pulley bolts, when doing the cam seals....
As for reinstallation, I use a little lock tight on the bolt, haven't had one come loose on me yet...
(Huck runs to knock on wood....)
Old 12-13-2005, 05:10 PM
immortal_suby's Avatar
Thread Killah
I've done the starter/breaker bar method several times and used a strap wrench to tighten the bolt back down but I recommend against using a strap wrench if you have the stock pulley - it could damage the rubber dampener.
In that case you can either use loctite and cross your fingers or buy or fabricate the right tool for the job.
Locker Link
2015 BRZ Limited 6MT
Old 12-13-2005, 06:00 PM
dromano's Avatar
dromano dromano is offline
what pulley?????/
Originally Posted by neptue
OK!
light pulley.
Thanks.
I have an Unorthodox Racing billet aluminum pulley, it weighs 1/5th the stock pulley, more hp, no problems in 33,000 miles.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 12-20-2005, 09:48 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
That's great, but he's interested in investing in a "ranch"....
1995 Subaru Svx L / AWD
Old 12-20-2005, 11:28 AM
davew833 davew833 is offline
Just wanted to chime in with all of those who use the starter/breaker bar method. I used it recently when doing my head gaskets and have also used it on Acuras and other cars I've done timing belts on. Just be sure you position the bar correctly so it doesn't fly up and hit the hood or something else when you bump the starter. Beats buying an expensive tool!
Old 12-20-2005, 12:02 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Cough or have your car actually lift up from the bar. (My brat lifted a good 3 inches when I loosened it a few years back but finally went).
