Old 12-07-2005, 09:30 AM
jamhamm
torque converter
ok so tranny went out a few weeks ago [big surprise there eh?]
got the new tranny from ebay ['97 legacy 88k - 99day warranty]
my question is - whats the story on my old tc?
shop said it doesn't leak and didn't have any debris but the shop of course
indicated that my labor wage would double if they have to pull it back out
after installing
the 'new' tc from the legacy tranny is smaller than my old and cannot be reused
so do i buy a new one at $167 local
pick up a 'known good' one off ebay for $50 plus sh
or trust my old one since the fluid was clean and its not leaking?
-sau
Old 12-07-2005, 11:26 AM
Earthworm's Avatar
Meow!
I would use the SVX torque converter but immediately flush the tranny. If the tranny is under warranty as you say it shouldn't be an issue to flush. Normally if there's a problem caused by flushing it will happen very soon.
Old 12-07-2005, 11:58 AM
jamhamm
well the tranny has a warranty but the labor doesnt
local shop is putting it in for 300 [aamco]
if they have to pull it back out cause the tc doesnt work then that's 300x2
i'd rather not pay $600
a known good tc is $50 on ebay plus shipping...
is the svx tc bullet proof - i honestly know nothing about the tc in a subaru
my tranny went out - when cold it would engage but wouldn't shift from 2nd
and once warm it lost all grip completely in every detent except park
no drive no reverse nothing....
so i didn't know if its safe to assume the tc is ok cause there wasnt any metal shavings when they pulled it
or safer to pay $70 to get a known working one shipped to the tranny shop and have them use that one...
or of course go the full route and get either mine rebuilt or one from an auto parts store - about $200 either way
-sau
Old 12-07-2005, 05:36 PM
oab_au oab_au is offline
Torque converters.
The torque converters give no trouble, it is the lock-up clutch in there that can be suspect. You don't have a model, mileage or history in your profile, so I can't be sure.
Some of the early 92 US models had a lining on the clutch that tended to flake off and block the cooler and the lube passages in the box. As you lost the high clutch followed by the forward clutch, I would think that it had the oil pick up screen in the box blocked by lining debri, Dropping the line pressure.
That said the SVX converter is stronger, so I would get them to drain the converter to see if there is any lining debri in there. If not use it, if there is don't use as it will continue to drop pieces into the new box.
I'd get them to reverse flush the cooler in the radiator to ensure that it is not blocked.
HARVEY.
One Arm Bloke.
Tell it like it is!
Old 12-09-2005, 11:17 AM
jamhamm
thanks harvey
i bought a new one just cause i didnt wanna pay for labor twice over
the shop that doing it isnt giving the best cust. service
ill just be happy when its all done
-sau
Old 12-09-2005, 12:18 PM
intelisevil's Avatar
intelisevil intelisevil is offline
<<<Alcyone
-sau
I don't know about anyone else but I'm thinking known good plus ebay is approaching an oxymoron?
Is the seller willing to pay for the labor to replace it if it turns out to be bad? I didn't think so.
As always with ebay, Buyer Beware.
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 12-10-2005, 01:08 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
Ditto that... person I bought this car from bought it off ebay... now Im replacing the trans that was supposedly replaced in July... go figure...
1995 850Ci
1988 Prelude~ B20 swap
2006 Mustang GT (RIP)
Old 12-12-2005, 05:34 PM
dromano's Avatar
dromano dromano is offline
When I had a rebuild done, the shop had the TC rebuilt by a specialty shop which tells me a better than original TC is insurance against earley failure. The TC is the source of heat in our tranny, if it's state of the art, that's a good thing IMHO....
2012 Outback 3.6R Limited!
Old 12-14-2005, 10:24 PM
pnyklr
It was supposedly replaced before June according to Brian at the dealer but who knows
Old 12-16-2005, 05:07 PM
Rotorflyr's Avatar
Rotorflyr Rotorflyr is offline
Homer says "Mmmm I bet pnyklr's avatar doesn't last long"
And jam, wasn't there a shop other then aamco you could have used?
1992 Liquid Silver LS-L (Sold-5/16/13)
1997 Spruce Pearl Outback (Sold)
2006 B9 Tribeca
Old 12-17-2005, 08:02 AM
pnyklr
homer changed it to a picture of the best car ever
Old 12-19-2005, 02:04 PM
Earthworm's Avatar
Meow!
Then he changed it to a pic of a GN
