Old 12-05-2005, 11:13 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Very Bad rattling??
Ok I have always had a slight rattle (sounds very tin like) from underneth the center of the car, this is after removing the noisy heat sheilding.
But yesterday i removed the exusaust from the cat back and went for a quick drive...damn it was loud and grubley i loved it haha, any way after the fun i put her back together and the vibration was worse.... a lot worse
i now have a rattle across all rev ranges, on full throttle it stops but on full back off it is embarasingly noisy....any ideas?
Could the contence of the cat be loose???
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 12-06-2005, 10:38 AM
Earthworm's Avatar
Meow!
Could it be the resonator?
Get under the car (safely) with a rubber mallet and start banging away until you find the rattle.
Old 12-07-2005, 05:52 AM
-JJ-'s Avatar
Endangered Species
I FOUND IT!!
The heat shield that is directly over the center baring on the rear drive shaft had lowered so it was just rubbing on the join, made a helovaraket hehe, got a screw driver and bent it out of the way, since doing that i have driven and it has lowered again, might weld it up or something
Old 12-07-2005, 09:35 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
No, no...use a lead one.........lol
1995 Subaru Svx L / AWD
