Old 11-22-2005, 07:06 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
steering wheel
Is there a way to center the steering wheel? Mine is a little off, and it bothers me. I had my wheels balanced, air checked and had a wheel alignment. The steering wheel is still off center. Any ideas?
Old 11-22-2005, 07:11 PM
Dan,
The alignment shop should have been able to center the wheel and make the alignment adjustments underneath to compensate.
Old 11-23-2005, 10:15 AM
Earthworm's Avatar
Meow!
What he said!
The steering wheel is centered with the rack. You don't want to change that.
It can only be fixed properly by another alignment.
Old 11-24-2005, 12:49 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
I can do it without an alignment machine.
The problem is whether or not the person doing the alignment has the total toe set correctly or if it is just a tweak off-center. If the total toe is correct one could just loosen one tie rod jam nut, turn the tie rod while counting the jam nut flats, tightening the nut and then adjusting the opposite side the same number of flats. (adjust the tires to the side the wheel is turned towards)
To be fair, sometimes no matter what you do during an alignment the wheel will come out a hair off. I've done too many to waste time re-mounting the alignment heads, etc. to just tweak the wheel to center. Hopefully your alignment tech can fix you up in a few minutes.
