car won't start (not the battery)
my car won't turn over at all doesn't even make a sound.
battery has volts and doesn't respond differnetly with jumper cables. can anyone diagnose? thanks |
Not even a relay click?
Does anything else work? Is your fusible link still intact?
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
'Not even a relay click?"
sorry for being a little ignorant but i don't know Does anything else work? yeah everything else works fine Is your fusible link still intact? again a little ignorant in this area thanks |
If everything else works, then your fusible link is fine. What I mean by the relay, when you turn the key to start, do you hear a click? When you turn on the ignition, do all the warning lights come on?
My guess is starter. Get out your 180 + labor to get it fixed :-/.
this happened to me 4 days ago in my garage, i turned the key twice, and i got a very loud distinct "CLICK" (just a single one i believe), but nothing gained from it.
turned the key twice, got this effect, rolled my eyes, and made a little curse, waited a second, and the car started. bad starter i was thinking. this guy probably has similar. |
I am also experiencing this problem. It is not the starter in my case - I had it rebuilt. There appears to be a problem with the terminal clamp or the cable between the battery and the starter.
Philip |
