Old 10-29-2004, 12:19 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Question Starter replacement
I'm going to have to be replacing my starter in the dark in a gas station parking lot. Any tips to making it easier? I looked in the How Tos and found nothing. Any help will be greatly appreciated.
Old 10-29-2004, 02:31 PM
87f383's Avatar
87f383 87f383 is offline
bring a flashlight!!!
acctually you are looking at an easy job....just a few bolts... dont even have to remove anything except the batt cable (safety first!). It will take <20 mins to do. Easiest starter in the world to change... imho.
1995 Subaru SVX
-Accel Green Filter *
-Flowmaster Exhaust
-ECU Stage 1 Chip *
-Alluminum Drive Pulley *
-Stage 1 Shift Kit
-Small Car Clear Lenses and Corners
-1997 SVX Grill
-17" X 7" Enkei Shoguns
*Thanks Dayle! (SVX Motorsports)
1987 Pontiac Formula 350
-Enough (Once I put it back together again)
Old 10-29-2004, 08:46 PM
THAWA
it might be easier to get the bottom bolt form under the car, if you wont have ramps you could try drivig your car up on a curb or omsething I dunno. :\
Old 11-01-2004, 02:40 PM
Hocrest's Avatar
It wasn't as bad as I was expecting. The darkness wasn't much of a factor since I couldn't see my hands, my tools, or the nuts and bolts that I was removing/replacing...
As this is the first starter I replaced on any vehicle I don't know if this is common or not, but the bottom mounting is not with a bolt. There is a stud into the trans with a nut (19mm??) holding the starter on. If I would have had to line up a nut into that bottom hole, I think it would have taken an extra 10 minutes and a whole lot more swearing...
I did have to remove the air intake, as I could not see of any other way to physically get the detached starter out of that hole that it lives in.
I think it took me about 30 minutes total.
Thank god for the $10 junkyard starter sitting in my basement
Now it's time to try rebuild the one I pulled out... Has anyone done that yet??
Old 11-01-2004, 04:08 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Glad everything turned out great! That must have been a real pain in the arse... Thank goodness for junk yard parts!
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-02-2004, 07:57 AM
87f383's Avatar
Told ya! Simple as can be.... Good Job!
1995 Subaru SVX
-Flowmaster Exhaust
-ECU Stage 1 Chip *
-Stage 1 Shift Kit
-1997 SVX Grill
Display Modes
