Old 10-13-2004, 06:20 PM
Dengue's Avatar
Dengue Dengue is offline
My kitten can woop your kitten
Send a message via AIM to Dengue Send a message via Yahoo to Dengue
electrical hell
I've replaced my alternator twice now, and it appears to be working now with the brand new optima red top I put in with it (bosch reman).
I have el gauges powered from the parking light switch on the lower left side of the dash.
I have a 750 watt amp and a 1 farad cap.
that said I have gone through a variety of electrical problems since I lost the first alternator. currently, my stereo (sony MEX-1HD) bugs out periodically, I find that if I leave the face plate off overnite, it will work fine the next day, but if I leave it on, none of the button or knobs on th stereo work, and it sort of just changes tracks on the hard drive or slides through the menus randomly....
ALSO.... the dash lights (not the el) and the center console shift indicator lights are on when the car is on, until I turn the headlights ON and then they turn off, fortunately the el light come on so I can see the speedo, but not the odo.
about 2 weeks ago my stereo stopped working entirely, I pulled the deck out unplugged the harness, pulled the fuse out (20 amp) checked it (it was good) put every thing back and the stereo worked fine, I did some cleaning up in the car for about an hour with the radio on with no problem, later that evening, I went to the store, and poof, no stereo again. this time my 15 amp radio fuse was blown under the dash, so, I replaced it, and within a day, pow, blown again, so, I replaced it again, determined to make it blow again and figure out what was causing it. that fuse has been good for about a week now.
none of this really affects the way the car drives, other than the mind bending frustration when I can't control my stereo, however I do believe that the situation is slowly making me insane...... what the heck is wrong with my car?
Skip
'95 SVX L - Laguna blue 126,000+ miles
'89 XT - some sort of sun bleached blue
'00 Hyundai Sonata- charcoal gray (hers)
Old 10-13-2004, 07:25 PM
intermittant short circuit on radio or gauge install? not easily diagnosed over the internet......all i can suggest is to pull the radio and gauges and check your wiring. make sure all connections are good and secure/insulated.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 10-13-2004, 08:07 PM
oab_au oab_au is offline
Re: electrical hell
Skip
A 1farad cap will act as a short circuit when it is first switched on. It needs a resistor in its feed line to limit the current flow.
Harvey
One Arm Bloke.
Tell it like it is!
Old 10-15-2004, 11:41 AM
Earthworm's Avatar
Meow!
Re: Re: electrical hell
I use an H3 fog lightbulb to do so.
Old 10-15-2004, 12:54 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
my recommendation is to check all your fuses ....what can happen is a blown fuse will always resemble a ground (with high resistance) but can sometimes be very low resistance ......when this happens the circuit backfeeds ground into anything else that is connected to that circuit .....basically - u turn stuff on, and something else shuts off.
Good luck
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
