Old 09-14-2004, 07:46 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Guage Installation questions
Okay, I did a search of the site and didn't come up with any concrete answers to the following questions:
1. Given the "coil per cylinder" set up with the SVX's engine, how do you hook a tachometer up (yes, I know we already have one, but it doesn't have a shift light you can set to a predetermined rpm...)?
2. Is there any place on the block that is already threaded to accept an electrical sender for a water temperature guage?
3. Is there any place on the block that is already threaded to accept a fitting for a manual oil pressure fitting (or an electrical sender)?
Thanks in advance for everyone's help on this.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-14-2004, 08:42 PM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Question
So, NOW what are you up to, Bill?
Remember, whatever you do it'll knock you outta' G stock.
Ron (I protest all cars that beat me).
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
Old 09-14-2004, 09:55 PM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
to answer#1 there SHOULD be a pick up from the distributor, I know there isn't one, but the standard term may be "tach" or "trig" or "trigger" somewhere near the ignition. There may even be a connection in one of the fuse boxes for a pulse for a tach. This will require a manual for the vehicle which I do not have. try calling a suby dealer, he may be able to tell you without charging you $$$.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 09-15-2004, 10:02 AM
SVXRide's Avatar
Ron,
Definitely nothing that will take me out of GS
Let's just say the SVX might be ready to see some action in other venues...
-Bill
Old 09-19-2004, 08:53 PM
lee lee is offline
Bill,
Can't say as I've looked when I had my Alternator off, but the newer 4-cyl models have the oil pressure sensor tapped into the top of the block below the Alt. I think the WRX guys put in a "T" for the pressure sending unit.
I would assume the same (putting in a "T") for the coolant sensor.
the thread below says pin 16 of the 16 pin connector at the ECU has the tach signal.
http://www.subaru-svx.net/forum/show...threadid=16843
Old 09-20-2004, 07:55 AM
SVXRide's Avatar
Lee,
Thanks!
-Bill
Old 09-20-2004, 12:58 PM
PatrickB's Avatar
PatrickB PatrickB is offline
Send a message via AIM to PatrickB
why not just install a shift light instead of a tacky tack?
Old 09-20-2004, 01:26 PM
lee lee is offline
well, if we're gonna vote on alternatives to what was asked I vote for the GTech Pro - which has shift lights as a part of their logic.
Old 09-20-2004, 07:39 PM
SVXRide's Avatar
shift light -- yep, you're right -- guess I've been figuring that the shift light depended on the tach's electronics to set the shift point at which it lights up .
-Bill
Display Modes
