Old 09-15-2004, 06:16 PM
Notall There
Question Oil Choice?
When i do the rebuild next week for the head gaskets, gonna get the service done as well!
What sort of oil is everyone running? Grade, etc?
The tech data book says 6l of 10w40! Anything make it run any better?
Phil
92 SVX (UK)
Old 09-15-2004, 06:50 PM
Jnthn_Sctt Jnthn_Sctt is offline
Re: Oil Choice?
Phil
92 SVX (UK)
Engine will hold 6.3 quarts. Plan on 7 with a new filter.
I use Mobil1 synthetic fluids in everything on my car, and have had no problems. Lots of other members swear by them as well, as well as RedLine products for trannys.
As for weight, with synthetic I use 10W30 year round.
In very hot climates, or hard use, (racing and such) 10w40 may be the way to go. But I've had no probs with 30
Jonathan
Old 09-15-2004, 10:21 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Depending on the conditions of your seals, if they're not leaky run Mobil 1 10W-30!
If you've had slight oil leaks in the past and want to run synthetic, then use Valvoline Max Life Synthetic 10W-30.
As my seals are starting to leak, I'm running regular Valvoline Max Life 10W-30 which has stopped my leaks completely and seems to work very well will my engine. In the future, I may try a 50/50 blend of the Max Life regular oil and synthetic.
-Chke
2006 Steel Gray WRX TR (sold)
Old 09-16-2004, 12:36 AM
Notall There
Thumbs up
Cheers guys, going 2 renew most of the seals when the engine's out, so better not be leaky after! lol
Old 09-16-2004, 01:47 AM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
I run Mobile-1 fully synthetic. It's probably a waste of money, but it does last longer than petroleum-based lubricants, and I'm lazy when it comes to changing oil. If I can put it off a little longer, it's worth something to me.
Some people claim to notice performance gains with synthetic oils. It was probably a placebo effect in the SVX, but I think it was significant in my motorcycle. The friction inside an engine is considerable. I would believe that this may have a real benefit. I know thinner oils are advantageous for this reason, and thicker oils are discouraged for economy reasons.
1994 LSi, Laguna Blue SVX Appeal
1992 LS-L, Ebony Pearl SVX-Rated
UberLocker
Old 09-16-2004, 01:52 AM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
I run valoline max life 10-40 anytime I change my oil.
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 09-16-2004, 07:19 AM
dcarrb dcarrb is offline
decisions, decisions...
Press the issue and you're likely to get just about as many brand, weight and composition recommendations as there are members on this forum. You won't go wrong abiding the specifications in your owner's manual, and selecting a reputable brand based on price.
dcb
Old 09-16-2004, 08:25 AM
Mr. Pockets's Avatar
Moderator
Re: Oil Choice?
What 'service?'
I use Mobil 1 synthetic, by the way, and have for a few years now. If you're replacing all the seals in the engine, you shouldn't have any problems. But it leaks out of my seals because they're old.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 09-16-2004, 11:00 AM
Notall There
Thumbs up
Mobil 1 it is by the look of it then!
Cheers guys!
