Old 06-28-2004, 11:59 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
Angry Stupid Brakes
Well, I finally had to replace my rear brake pads and came across a few problems.
Problem 1: During the replacing of the pads, I made the nice discovery that my driver rear caliper is stuck. The pads look very new and the rotor looks unused, so I left it be being that I couldn't unstick the caliper. On the passenger rear, I got the pads in but now sounds like there is a metallic noise as though the rotor is slightly warped and slightly brushing on one small portion of the rotor.
Since the install, my brake light comes on all the time. I've bled the brakes and everything and am wondering if it could be that the one caliper isn't making any contact and thus a warning is sent to the ECU, or whatever determines what makes the light come on.
Problem 2: Every once in a while since the install of the brake pads, a really loud grinding noise comes from the brakes on the supposed siezed caliper.
It won't be a problem to get new brakes, but I really don't want to spend money if what I have is still good, with the exception of the finicky siezed caliper. The car brakes fine, but just has a few bugs to work out.
Also, When bleeding the brakes I discovered that the SVX brakes run in a diagonal pattern, meaning that when the driver front brakes are bled the passenger rear brakes need to be bled as well and vice versa.
Please help figure out this sometimes noisy problem.
Thanks again,
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 06-29-2004, 01:26 AM
When you bleed the brakes, there is a sequence that you need to do. I don't remember what it is, but you can do a search and find out what it is.
I would get the caliper that is not working fixed. Then you can get things working properly. Good luck
Old 06-29-2004, 01:28 AM
HighwayUFO's Avatar
That is my plan come Saturday, and I will check on the bleeding sequence right now. Oh, by the way, the Pearlie looks good.
Keith
Old 06-29-2004, 02:23 PM
Mr. Pockets's Avatar
Moderator
Re: Stupid Brakes
That doesn't make any sense because there are no sensors to detect such an issue.
Thanks again,
Keith
As for the seized caliper, that's a recurring problem on nearly every Suaru I've owned. The calipers are a sliding type, and you have to make absolutely, positively certain that the slides and boots are clean and well-greased with caliper grease. You may have to remove the slides and clean them with a fine-grit sandpaper to remove corrosion.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-29-2004, 02:52 PM
dcarrb dcarrb is offline
The BRAKE light indicates low brake fluid in the master cylinder, and does double-duty to show when the parking brake is set. Try unplugging and reconnecting the wiring to the sending unit on the base of the master cylinder.
dcb
Old 06-29-2004, 02:54 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Look in my locker for brake info.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-29-2004, 02:57 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Re: Re: Stupid Brakes
Caliper grease???
You mean the Crisco shortening I used isn't going to work??
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 06-29-2004, 03:04 PM
Word to Yo Motha
Re: Re: Re: Stupid Brakes
Originally posted by mohrds
Caliper grease???
Doug
Planning on baked brakes for dessert??
Collin
1995 L AWD
Locker
Old 06-29-2004, 03:46 PM
Re: Stupid Brakes
Keith
Keith, in the past I have had the brake light come on [I assume you mean the one on the dash?] for no good reason, usually after new pads or something affecting the level.
I find mine needs the reservoir full right up to avoid this. Careful overfilling though, that rubber bulb thing displaces fluid and you don't need that nasty stuff all over everything.
My guess is the white plastic float device {which causes the light to come on if the fluid level is too low} can get pushed sideways when closing the lid. Then it is not free to rise to the upper level, and as a result, the light comes on.
Open it [the reservoir] top up a little if necessary, and ensure that float device is not pushed out of line by the lid on closing.
