Old 06-01-2004, 02:39 PM
fait_svx's Avatar
fait_svx fait_svx is offline
Sleeve-lock regulator installation
Ok, I have the sleeve-lock regulator in place. The window went up, but it wont go down. And, I have alot of slack in the wire. How do I tighten it up? Would this be the reason why the window will not go down? Also, the round pulley inside the door near the top has been cracked around the edges somewhat. How do I replace this? Help me out here guys, this window hasnt worked in almost 5 months.
Old 06-01-2004, 03:14 PM
fait_svx's Avatar
heres a few pics I just took
Old 06-01-2004, 03:17 PM
fait_svx's Avatar
Old 06-01-2004, 03:21 PM
fait_svx's Avatar
Here is a pic of the motor. Is the adjuster screw somewhere in this pic?
Old 06-01-2004, 03:30 PM
fait_svx's Avatar
Old 06-01-2004, 03:32 PM
fait_svx's Avatar
Here's an idea of the amount of slack I have? How do I tighten this? And is this why my window wont go down?
Old 06-01-2004, 03:35 PM
kayvon's Avatar
kayvon kayvon is offline
Did you slip the sleeve lock regulator between the hex shaped piece that connects the wire cable together?
I am not sure why you have so much slack
I replaced mine last week
Kayvon
92' SVX
www.sounddomain.com/id/kayvon
Old 06-01-2004, 03:39 PM
fait_svx's Avatar
Old 06-01-2004, 03:42 PM
fait_svx's Avatar
Yea I did. The reason why I have so much slack is because I to pull the wire to get that hex shaped piece to match up with the t-shaped hole in the window. But when I connected everything, the window did move up, but now it wont go down.
Old 06-01-2004, 03:49 PM
fait_svx's Avatar
Heres a pic of the passanger side door. This is exactly how I installed the sleeve-lock regulator. And, it gives anyone trying to install it, an idea of what it is and how it fits in the window.
Old 06-01-2004, 03:51 PM
kayvon's Avatar
When I replace my regulator. I used the power window switch to adjust the hex piece in place so that it would line up to the regulator. I don't know what happens when you pull on the cable.
Kayvon
92' SVX
Old 06-01-2004, 04:02 PM
fait_svx's Avatar
Well yeah I did the same thing but, for some reason it wouldnt line up to where I needed it to be. There was already some slack to begin with, but not enough.
Old 06-02-2004, 03:02 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Originally posted by fait_svx
You may need to just buy a new or good used regulator.
From the dealer they are about $95
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
