Old 03-29-2004, 08:16 AM
Mr. Pockets's Avatar
Moderator
Legacy FWD fuse no longer works
Yes, you read that right. See, duty solenoid C in my Legacy is bad, causing some binding during turns. So I have the FWD fuse in until I get around to replacing the solenoid and the clutches. That's been a fine solution until now. All of the sudden the fuse doesn't seem to do anything (the car is no longer in FWD mode) and, of course, it's telling me that duty solenoid C is bad. I tried replacing the fuse, but that didn't do anything - the one that was in there was fine, of course. If it was blowing fuses I'd have much bigger problems.
Any ideas? I am going to hook up my OBD-II scanner and reset everything to see if that helps.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-29-2004, 02:08 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
When my FWD fuse didn't work, it turned out I needed a TCU.
Randy Johnson
Mike Davis -- at Reading VI
Old 03-29-2004, 02:24 PM
Moderator
YAY!
2005 Outback
END OF LINE
Old 03-29-2004, 03:04 PM
Aredubjay's Avatar
Originally posted by Mr. Pockets
YAY!
I figured that'd make you happy.
Randy Johnson
Old 03-29-2004, 05:57 PM
oab_au oab_au is offline
Doom and gloom.
Nick don't you just like these blokes that tell you the worst news first.
It depends on the FWD light on the dash, is it still working? If it is then the binding is caused by pressure being applied to the clutch by a stuck Transfer valve. The C solenoid may be working ok but the stuck valve won't let go.
If the FWD light does not work with the fuse in, then sh1t has happened.
One Arm Bloke.
Tell it like it is!
Old 03-29-2004, 07:08 PM
Moderator
I suppose it's possible that the light burned out. But I don't find it likely because the binding came back as soon as the light stopped working - that and the tranny light started blinking. I keep forgetting to take my OBD-II scanner home with me. I'm grabbing it right now and I'll see what I find.
2005 Outback
END OF LINE
Old 03-30-2004, 01:53 PM
Moderator
Well, here's an odd little update. Last night I tried disconnecting the battery while I ate dinner. I went back out, full and burping (you're welcome for the imagery), hooked the battery back up and started the car. No more blinking tranny light (go figure), but also no FWD light. I went back inside, feeling a little defeated.
My wife says that the car's been fine all day. FWD light is back on and no binding.
I don't think my battery trick did it. Right now I suspect a bad ground. So I guess I'll have to hunt down where that fuse grounds to. There are a couple little grounds close to it, but I'd be overly optimistic to expect that one of those is it.
2005 Outback
END OF LINE
Old 03-30-2004, 03:04 PM
Looks like IT has happened.
Looks like it is electrical. If you can find the 'FWD fuse' wire at the TCU plug, you could check to see if it has 12V on it when the fuse is in, if not you can work back to find the problem. If it has 12V there, then check the C SOLENOID wire at the TCU plug, see if it is there. Yes?, it is the C SOLENOID, no?, it is the TCU. Sorry I don't know the pinout for the Legacy.
One Arm Bloke.
Tell it like it is!
Old 03-30-2004, 03:28 PM
Moderator
To be completely honest, I don't know where the TCU is on the Legacy.
2005 Outback
END OF LINE
Old 03-30-2004, 04:05 PM
Aredubjay's Avatar
More organic mac and cheese, no doubt.
Randy Johnson
Old 03-30-2004, 06:03 PM
Moderator
Funny, but no. It was home made goodness.
2005 Outback
END OF LINE
