Old 08-07-2001, 08:11 PM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
ATF filter before or after stock cooler
Is the external ATF filter supposed to be installed after or before the oem atf cooler?
which pipe from the radiator flows the atf to the tranny and from the tranny, driver side or passengers side?
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 08-08-2001, 06:52 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
My filter lines run from the tranny to the filter, then to the passenger side of the radiator, then from the driver's side back to the tranny, So I would assume the passenger side is the inlet, but I can't guarantee it. Mine was installed at the dealer during the campaign.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 08-08-2001, 07:58 AM
htyei's Avatar
according to the subaru svx service manual it should be the other way around...,
Im beginning to wonder if everyones filter is installed that way.
Maybe its a typo of the manual?
or maybe it REALLY doesnt matter which which side of the atf cooler the the inlet and outlet should go..
Henry Yei
htyei@svxwrx.com
Old 08-08-2001, 09:33 AM
mohrds's Avatar
Perhaps the configuration of lines for the campaign filter ended up changing the flow to allow for proper line bends, or perhaps Subaru purposly engineed the campaign to reverse the flow to allow a continuous backflush of the potentially clogged stock filter.
They may have planned for a few dealerships to shortcut the backflush during the campaign and figured this was a good solution. We'ed need to see a SVX that wasn't brought in for the campaign filter to prove whether it was a manual typo or planned.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 08-08-2001, 10:22 AM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Doug
Doug you are correct,The inlet is on the passenger of the radiator.
Old 08-08-2001, 03:28 PM
htyei's Avatar
glad tahts cleared up
Whew, glad to know Im not the only one with that configuration.
I was worried that I'd have a dead tranny on my hands soon, because of having the filter on after the cooler. (whats the pt if your cooler gets clogged b4 it even reaches the filter?!)
I guess I'll maked a little admendment in my manual
[atf cooler inlet - passenger side] to [atf cooler outlet - driverside]
[atf cooler outlet - driverside] to [atf cooler inlet - passenger side]
Henry Yei
htyei@svxwrx.com
