Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 06-19-2016, 03:11 PM
Lamborghini doors
Instal them ?
Old 06-19-2016, 03:12 PM
Re: Lamborghini doors
Anyone have or know someone that has them? Just curious as how do they hold up ? Do they solid lock? Do the rattle. Think the SVX door too heavy? I d it and there are lot out there.
Old 06-19-2016, 08:49 PM
http://www.subaru-svx.net/forum/show...ighlight=lambo
None ever opened a full 90 degrees. A Lamborghini door unlatches and smoothly goes straight up. In the SVX, the door has to unlatch, swing out slightly to clear and then go up.
The original kit was made by Skydoor and was expensive and a lot of fabrication was needed.
Old 06-19-2016, 09:17 PM
Just looks cool parked with them up. No matter how they open the End result looks the same. I would be more concerned about the weight and the not tight fit ( rattle. ) Nice because you don't have to use them that way always. You can just open normal. It's been 5 years since last discussion. They have been made better since then. If I did it it would be my final mod. .i would have to ride in a car that had them. As the do close Normal the last 5 inches they should seal and latch as sound.
Old 06-20-2016, 06:34 AM
Please don't. The mod has been over done in the tuner scene.
Old 06-20-2016, 01:08 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Conn your Lambo doors would never fit in your portable.[IMG][/IMG]
Old 06-20-2016, 01:10 PM
SVX92-97's Avatar
Lambo doors would be a tight squeeze
Old 06-20-2016, 01:13 PM
SVX92-97's Avatar
Conn, you have officially been named KingConn Most SVX trophies in CT.[IMG][/IMG]
Old 06-20-2016, 01:17 PM
SVX92-97's Avatar
You gonna add anymore Bling this year
Old 06-20-2016, 01:19 PM
SVX92-97's Avatar
Bet that Hood is gonna look awfully sweet wrapped
Old 06-20-2016, 01:49 PM
SVX92-97's Avatar
I hope we dont see anymore scenes like this after the makeover
Old 06-21-2016, 07:12 AM
Doors can still open out as normal
Shelter logic garage is 12X20 x10 tall
And it is a daily driver. So it might see snow
Old 06-21-2016, 07:18 AM
Garage is tall enough
Old 06-21-2016, 03:00 PM
This was a 1966 SVX converted around 2010. A former member here from New Britain, CT.
He ended up ripping them out because the shocks kept failing on our extremely heavy doors. Said it was impossible to try to slide into the seat while holding the door up.
Bringing them down was just as bad. Said they never aligned right and the doors would sag when opened. Would have to be raised up about 5" to be able to be pulled in to latch correctly.
Needed the correct strength shocks with the right amount of extension
And just how do you buckle up and reach the door to close it. Or worse yet, your 5'5" girlfriend?
Old 06-21-2016, 04:59 PM
The set up is a lot different now... Talked to a Ricer Speed shop. He talked me out if it too.. Said it tears up the door cards, also the sagging issue. A lot of welding as none are made for SVX saw some on Mustangs and Cameros that were good butt were made as bolt on... Also said once they sag almost impossible to fix and it will start making dents on the door edge. Was a cool idea. Found a guy that would so it fro $800 installed. Tempting it was....
