Old 04-08-2003, 02:19 PM
StaceyVX
Check Engine Light & Exhaust Buzz
Okay, I put this in another post in another forum, but I wanted to get some more opinions...This is on a 92 SVX...I just want to know if you would buy this car with these issues and mainly if the CE light is a big issue. I know one issue is that if it's not fixed, you won't know when something DOES go wrong.
"There are a couple non-issues that someone might decide they would rather have taken care of - one is the 'check engine' light on the dash comes on intermiitantly: it's been that way for years; I had the dealer evaluate it and was told that when they hooked up the computer to it, since it was triggering error codes randomly and with no pattern, then they decided it must be a fault in the wiring harness and it was up to me if I wanted them to perform electrical diagnostics to see if they could pinpoint ithe source of the false errors. Since such work could take hours, I decided it wasn't worth it, and that I'd live with the light.
The other one is in one of the exhaust pipes - when the tach is exactly on 2k, and only 2k, you sometimes hear a buzzing sound. This comes from the fact that inside a sealed area in one of the exhaust pipes is a section containing baffling, and one of the baffles has come loose, and as the air passes through it, at a certain speed, it causes it to vibrate at a certain harmonic. When I had this looked at, they told me it was again my choice whether to replace it for a few hundred bucks (dealer cost; I'm sure it's a lot less with used parts), or to just live with the harmless but sometimes annoying sound. So since I wasn't going to drive it terribly often, I chose not to spend on the replacement. This also was several years ago."
Old 04-08-2003, 02:43 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
I'd consider the C/E light a potential big deal and get a dealer to check it out - nothing against the seller, but some people trying to sell their cars have been known to lie a time or two.
The exhaust isn't a big deal - it's probably a resonator and can be replaced with straight pipe by any muffler shop for pretty cheap. It might be a little louder, but that's not necessarily a bad thing.
And welcome to the forum, and good luck on your decision!
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 04-08-2003, 02:59 PM
StaceyVX
Thank you 3 times over.
Old 04-08-2003, 03:05 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
agreed with Dick!
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 04-08-2003, 03:47 PM
sfsvx's Avatar
Twice is usually enough for me, I'm a pretty humble guy.
Dick
2001 Outback Sport
Old 04-08-2003, 05:02 PM
Re: Check Engine Light & Exhaust Buzz
When my exhaust was buzzing, just as you describe Stacey, it was caused by the heat shield above one of the cats. My tire and exhaust dealer fixed it, by applying a small spot or two of bronze weld to the loose heat shield. Has not buzzed since, from nearly two years ago. Minimal cost.
Get this checked out before you spend on a fix. Could save you $$.
Old 04-08-2003, 05:30 PM
Seraph's Avatar
I am still calling for the resonator. Put it on a lift, get someone to sit in it and rev it up. See where the noise is coming from. Easy fix/find.
L
Current SVX: NONE
Old 04-09-2003, 07:44 AM
StaceyVX
Thanks...I'm not sure if I'm getting the car after seeing it, though. (See "I Need Advice...Again" thread in general forum).
Old 04-09-2003, 03:09 PM
red95svx
I had a similar exhaust rattle and it was fixed with a couple of spot welds to a loose shield. Very cheap, very effective.
As for your mysterious trouble codes: I've seen a few Subaru's that did this and they all needed the same thing...a new computer. Hopefully you won't need one ($$$)!
Old 04-10-2003, 06:51 AM
StaceyVX
AHHHHHHHHHHHHHH! Soemthing's telling me to forget that car...
Old 04-10-2003, 10:36 AM
Seraph's Avatar
If the car is in Philly, some of us can come out and check it out over the weekend.
I am still not sure if I am coming yet. Doug has been asking. I am going to exchange the throttle bodies again and see if it helps. Also, I need to go see a judge on Friday AM and I can't afford to put the car in the garage at this time.
L
Current SVX: NONE
Old 04-10-2003, 12:09 PM
StaceyVX
Lwin, yea it's in Philly, but there's so much stuff I'd wanna do to it to make it look decent, I don't think it's worth it considering he wants BlueBook value. He left out a lot of things (as I said in the other thread where I asked advice) and that made me mad that I drove all the way over only to find out there was a bunch of things wrong.
I am looking at PittKid's car now and I'm trying to find out if anyone here lives near him that would be able to check it out for me.
