Old 04-01-2003, 06:03 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Center Console
The center console from the emergency brake back wobbles like crazy. I don't have a clue as to where the screws are that hold this to some invisible bracket underneath. Does anyone know how I might tighten this piece?
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 04-01-2003, 06:23 AM
Bobb Bobb is offline
console
Hi Michael, Open the lid, then lift out the cover over the bottom, and you will see screw heads. Tighten away. You also might see some under the rear ashtray after you remove same. BOBB
Old 04-01-2003, 08:32 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
More than likely, the plastic is broken, around the screws, from someone "pushing off" of the console when exiting the back seat (common problem). Find some small washers and glue them into to position to reinforce the holes, prior to tightening your screws.
Just a thought.
Randy Johnson
Mike Davis -- at Reading VI
Old 04-01-2003, 08:38 AM
Thanks Randy...you are probably right about that. Do I have to remove the entire console to do that?
Michael
Two-owner:169K
2008 Toyota Prius
Old 04-01-2003, 08:43 AM
Aredubjay's Avatar
No, just the felt liner on the bottom of the console chamber and the rear ashtray. You should be able simply to place your washers from there. Obviously, if you want to go to the trouble of "double" reinforcement (washers top and bottom) you'd have to remove it, but, depending on the level of "breakage," you should be able to make do with one washer on the top.
Randy Johnson
Old 04-01-2003, 06:57 PM
nordique14's Avatar
Who watches the watchmen?
I fixed mine
I fixed my loose center console a while back. It was really bad. Check out the post:
http://www.subaru-svx.net/forum/show...&threadid=5279
Cheers,
Old 04-02-2003, 08:32 PM
Mine was really bad as well. I cut an appropriate size piece of tile and drilled 3 holes in it to match the 3 screws in the console. Now it's REALLY solid!!
Old 07-15-2003, 05:51 PM
Chicane Chicane is offline
Anti-BS Vigilante
Where'd you put the tile???
Old 10-01-2003, 08:39 PM
The tile covers the entire bottom inside the center console. I am still waiting for the genuine SVX console mat I ordered to come in so I can cover the tile up.
Old 10-01-2003, 08:51 PM
how much was the SVX mat? you can buy a whole roll of grey or beige automotive carpet (trunk liner) for like $10. i did this for my armrest insides and the console. still have a sh*tload left over. maybe i'll make a disposable trunkliner.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 10-18-2003, 08:52 PM
I don't know, it never came in. (seems to happen with half the Subaru parts I order)
