Old 04-04-2003, 12:06 AM
How did you change the U joints? Did you use a press, or some other equipment. How about balance?
Old 04-04-2003, 11:42 AM
AutoTchr AutoTchr is offline
Press em out. Clean out the bores. (tip- use a ball type brake cylinder hone and atf or some other lighter oil.) Press the new ones in and install the c clips. I don't know if a hydraulic press is needed or not, I just ordered them the day before yesterday. Normally I just use a bench vice, but this case will probably require more force.
Properly installed, I have never upset the balance of a driveshaft by changing the u-joints.
ASE Master and L1 cert. Discounted Repairs
I feel a lot more like I do now then I did before.
92 SVX 5spd, (sold),92 SVX Teal, 67 Mustang 351C 5spd, 00 Galant.
Old 04-04-2003, 12:35 PM
mbtoloczko's Avatar
sans SVX
The original u-joints are staked in, so it will be necessary to first clean off the bits of metal that have been staked. If for some reason the replacement u-joints do knock the driveshaft out of balance, you can always get the driveshaft rebalanced. Sould be about $50.
Mychailo
Visit my locker
