Old 03-17-2003, 07:36 PM
Paxton71
NSK front wheel bearings packing grease?
I got the front bearing apart. I bought a bearing from NAPA, not Subaru. It is an NSK bearing. The grease in the bearing is clear/white. Is it packing grease or real grease?
Thanks, Stephen
Old 03-17-2003, 07:43 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I know its a bit off topic, but I'm confused. Normally is the packing grease put on for storage? Do we have to soak it in alcohol or something to get it off and then repack with real bearing grease?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-17-2003, 07:50 PM
Paxton71
grease already in bearing.
That is exactly my question, Tim. Am I looking at packing grease, or real wheel bearing grease?
Getting the old bearing out of the hub was all my 12 ton press (and sledge hammer) could do. I'm not interested in a redeux.
Right now, I'm going to repack the bearing with real grease without removing the existing grease with solvent.
kind of a split the difference approach! *laughs*
Old 03-19-2003, 10:16 PM
jsvxstyle jsvxstyle is offline
MINEZ BETTER
nsk are the o.e. bearings
repack them good and put them in
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon
Old 03-19-2003, 11:05 PM
mbtoloczko's Avatar
sans SVX
Re: NSK front wheel bearings packing grease?
Thanks, Stephen
Don't use the packing grease. Degrease the bearing and repack it with good wheel bearing grease. If the bearing has a plastic retainer for the rollers, degrease with something that will not destroy the plastic.
Mychailo
Visit my locker
Old 03-21-2003, 07:02 AM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Re: grease already in bearing.
If you're not interested in a redux, remove the original grease and repack the bearing. It's not that much extra work, and considering the stress the bearings are under, splitting the difference doesn't sound like the best idea.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
